Cisco Unity: Obtain MAC Address from Users
CLovett
I am working in Cisco Unity Version 11.5.1.14900-11
I have worked with a counterpart to this product, CUCM, in the past, but this is my first experience with CUCA.
I am curious to know if there is a module within the standard CUCA 'directory' (looks more like a table of contents starting with the Users node) that will allow me to view the MAC address of the phone associated with a user extension.
I recall being able to find this information quite easily when using CUCM, previously, but for all of my looking I cannot find it in CUCA.
Is it there?
-Chris
2 Accepted Solutions
Scott Pedersen
CUCA assigns voicemail boxes by extension. You will want to use CUCM to gain information about the devices the extensions are assigned to.
Jaime Valencia
CUC has no visibility of such information, in reality, it doesn't even care what kind of device you use to reach/use CUC as long as the CUCM/CUC integration is properly configured.
All the info you want, is in CUCM.
java
if this helps, please rate
Scott Pedersen
Jaime Valencia
java
