Cisco VCS and LDAP for User Authentication
William Bell
I have a question about configuring LDAP for user authentication on the VCS. I want to have redundancy in my LDAP link. I believe this is possible by setting the LDAP server address to a FQDN and then selecting a resolution type of SRV. What I am unclear on is what the value for the server address would be if I was indeed using SRV as the resolution type. I should also add that I am looking to use TLS
To clarify, if my AD domain is myad.netcraftsmen.net. Would I configure the server address field as:
myad.netcraftsmen.net : assuming that VCS will properly query DNS for the correct _service._proto parameters?
or would I need to create a new SRV record for this purpose and configure the server address field with the specific address (including the _service._proto fields)
or would I need to specify one of the SRV record formats used by MS AD domains (there are several).
If the latter, then which SRV record for TLS. I only see records with port 389 (non-secure).
My intuition tells me that it is probably the first option but I could be way off.
Anyway, thanks in advance for any input.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
awinter2
Level 7
Level 7
Hi William,
I just checked this on an X6.1 VCS, and it seems the VCS performs an SRV lookup on _ldap._tcp.domain (Where 'domain' has been input as the Server Address), both when encryption is set to 'None' and 'TLS'.
Hope this helps,
Andreas
awinter2
Level 7
Level 7
Hi William,
Hope this helps,
Andreas
Andreas,
Thanks for the rapid response. So, if I had the following configuration:
Server address: myad.netcraftsmen.net  (assuming that is the DNS zone for my AD)
Server address resolution: SRV
Port: 636
Encryption: yes
Then the VCS will query DNS for an SRV record: _ldap._tcp.myad.netcraftsmen.net? And then negotiate a secure connection?
I just want to make sure I follow.
Bill
Yes that is correct William.
OK. Well, thanks again!
Bill
