06-10-2015 03:01 AM - edited 03-18-2019 04:34 AM
Can we change the NTP server to a in-existent IP or block the reachability to NTP server to workaround the below Bug.
Upgrade or a Planned Reboot doesn't seem feasible. Kindly suggest
Solved! Go to Solution.
06-10-2015 06:20 PM
It's only going to be a problem on your device if it happens to query the NTP server at the exact time that it responds with "60" as the seconds... a second before, or a second later, and it'll be alright, so I'd think you'd need to be pretty unlucky to hit this bug.
But, yes, you could assign the VCS a non-existant, or unreachable NTP server over that time period, in which case it then won't query anything to get the "60" second time, then return it to normal operation afterwards.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
06-10-2015 06:20 PM
Wayne
06-29-2015 09:23 PM
May I know which time zone it is affecting or it is affects the local time zone?
i.e GMT will affects at their 23:59:59 but GMT+8 time zone will be affected 8 hours later.
06-29-2015 10:13 PM
The official answer is that it happens when the UTC time clock changes - so there will be that one second after 23:59:59 where the clock reads 23:59:60 before going to 0:00:00.
See https://en.wikipedia.org/wiki/Leap_second
Wayne
