11-06-2017 05:37 AM - edited 03-18-2019 01:35 PM
I have few TP end device MX300 G2, 1 nos of CUCM Publisher & 1 Subscriber, 1 TP Server and 1 TP Conductor. I have registered all TP end points into CUCM by configuring manual IP and static provision by selecting "Cisco UCM"in provisioning wizard.
Everything work fine, however all TP end point will unregistered after CUCM publisher goes down, i can understand i have given only CUCM publisher ip while provisioning but is that any other way through which we could achieve TP end point failover on CUCM subscriber if CUCM publisher goes down?
Or its not possible to have TP end point failover when CUCM publisher goes down?
Thanks...
11-06-2017 12:30 PM
11-07-2017 11:41 PM
Thanks for your reply.
Yes i have call manager service running on CUCM SUB, my all phones working fine on SUB, only VCS End point failover is not working? as i thought that is because of manually adding CUCM PUB ip in VCS end units while provisioning?
Please clear my understanding, how would VCS end point knows about CUCM SUB as we dont added any manual entry or provision for CUCM SUB?
11-08-2017 10:02 AM - edited 11-08-2017 10:03 AM
Hi Vishal
Did you add SUB CUCM neigbour zone on the Expressway-C ?
You should add all cucm server there,
11-08-2017 11:53 AM
Did you add SUB CUCM neigbour zone on the Expressway-C ? No I don't ...
Can you please share relative link/configuration to do the same..?
