05-27-2015 12:44 AM - edited 03-18-2019 04:31 AM
I get the warning "Insecure certificate: This cystem is using the default server certificate. We recommend...." On my VCS`es
1. Is there anything I have to take in consideration related to Endpoints or other VCS`s (this is a cluster) before uploading a New certificate?
2. Will communication between endpoints be affected?
Solved! Go to Solution.
05-27-2015 02:21 AM
If you are looking to get your certificates signed by your own or a public CA i would first make sure your servers have hostnames and relevant DNS records configured. In addition to this, if you plan on using collaboration edge (MRA) you should take a look at the additional SANs required for this:
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-5/Mobile-Remote-Access-via-Expressway-Deployment-Guide-X8-5.pdf
You shouldn't have issues with endpoints being affected, in my experience the certificates have only affected collaboration edge.
Thanks, Simon
05-27-2015 02:21 AM
Thanks, Simon
