Any Ideas will help.
I have installed a new out of the box room 70D G2 system. It came with ce9.7.1 on it.
I upgraded it to Ce9.8.0 and was working.
Someone prior went in an upgraded it to Ce9.9.2 and now the Camera power nor the two monitors show any power to them ???
Can't figure out what caused it but I did see cable changes.
1. The camera control cable was moved to the control input 3 (RJ45). I moved it back to input 2
2. The USB was moved down on USB slot. Imoved it back to the first USB.
Performed Factory reset.
Other than that everything is the same. No indication that the power to the camera on the camera side was messed with nor the power to the first or second monitor
Real head scratcher
Chet Cronin
