07-31-2019 10:00 PM
Hi all,
We have a client that has a MSE cluster with 5 x 8510s, with 2 of these being clustered into a single cluster separate from our Conductor.
Entity 1
TMS > 1 Clustered MCU > 2 x 8510s
Entity 2
TMS > Conductor > 3 x 8510s
We need to expand on entity 1's port capability and they are reluctant to move to CMS just yet. Is it possible to add a 4520 or 4510 to the 2 clustered 8510's so that it looks like this:
TMS > 1 Clustered MCU > 2 x 8510s 1x 4510
I can't find any similar documentation on if this is possible.
Any advice would be appreciated.
Solved! Go to Solution.
07-31-2019 10:17 PM
The Admin Guides say that a "Cluster" can only be made on MSE8510 blades, so you wouldn't be able to add a 45xx to a cluster.
07-31-2019 10:17 PM
07-31-2019 10:21 PM
Thanks so much Wayne, it's not perfect but we will remove a 8510 from the Conductor pool and cluster it with the MCU cluster and add the 45xx to the conductor pool in place.
Thanks for your quick answer mate.
