CME GUI
tkavithas87
Hi all,
i have an issue with the CME GUI.
normally when we add new phones to the network the phone will appear on the GUI.but one of the phone is not appearing.but this phone is registered.can able to configure using CLI.what could be the cause?
thanks
kavi
paolo bevilacqua
GUI has many limitations. Use CLI only for sure and fast results.
Jorge Armijo
Level 4
Level 4
Probably if you look at the CLI, you'll find ephone "x", make sure that tag number is not higher to the max-ephone under telephony-service. there is a known bug about it, I just can't remember the ID at the moment.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
