CMR Hybrid with active active TMSXE behind a load balancer
jdedell12
Level 5
Level 5
Working on a design as we are deploying a redundant video infrastructure which will integrate with WebEx using CMR Hybrid.  The question I have is when configuring One Touch on the WebEx Administration side it wants the host name of the TMSXE server.  Since there are two do I use the host name of the load balancer or is there a way to enter both TMSXE host names?
John
Jonathan Robb
the TMSXE cluster FQDN that resolves to the Load Balancer IP.
-Jonathan
Thanks Jonathan.  That is what I thought but was not sure.
