CMS 2.3 - issue with meeting lock/unlock and Join Start mute for participants
rajesh.kumar
Level 7
Level 7
We have Cisco CMS 2.3.7
Objective is to lock the meeting by host during  WebRTC meeting
We have Call Leg profile with callLockAllowed=true parameter
WebRTC page we could see "Meeting Lock" option. Once we clicked Meeting lock button.(turns gray) after few seconds it turn blue icon. But meeting lock doesn't work. Still endpoint could join meeting into that space.
Any suggestion how to achieve meeting lock on particular Space.
Secondly, we want to enable join start mute for all the participants. Host should be able to "unmute" it later when required. txAudioMute=true simply mute endpiont starting from the join and host can't "unmute" if required.
Pls. suggest
JUAN MANUEL MUNARRIZ
Frequent Visitor
Frequent Visitor
I hope this info will help you and other people in the same situation
We have a two member CMS1000 cluster in version 2.3.10
The problem appeared when we shutdown one member for maintenance purpose and it was solved putting in service the stopped member.
Cisco has documented the ploblem in BUG id CSCvn59705 which is in status "Terminated"
Best Regards
Juan Manuel Munarriz
bejoy.cisco
Level 2
Level 2
Hello, where you able to fix the meeting lock issue ?
callLockAllowed=true parameter - worked after CMS upgrade to 2.5
but other unmute issue, still exists. Seems, CMS designed like that.
