CMS 2.3 node participantlimit
Mamdouh Elgamal
I'm trying to understand Call bridge behavior when participant limit is reached.
given a call bridge group with 3 nodes, cb1,cb2,cb3 (all in the same cluster)
suppose i create a meeting in TMS and assign CMS resource + video endpoints. Meetings settings are set to have the bridge dial-in the endpoints
TMS reaches out to CB1 to create the meeting, but CB1's participantLimit has reached the max (i'm referring to participantLimit set @ /system/cluster object)
I'm seeing that cb1, just rejects the call:
add participant "xxxxx@zyx.com" request failed: call bridge unavailable
API provider: call control participant create failed (21)
shouldn't cb1 forward the call internally to cb2 ?
what is the expected behavior ?
The interesting thing, if i changed the meeting connection settings in TMS to have the device call the bridge number. The call connects on cb2, no issues.
EDIT:
i suppose this document answers my question..
https://www.cisco.com/c/en/us/support/docs/conferencing/meeting-server/212298-cisco-meeting-server-acano-tms-integ.html#anc9
but i't seems i need to route the call through CUCM if participant limit is reached on primary server.
0 Replies 0
