CMS 2.4.2 WebRTC - Joining meeting failed If the WebRTC client in any subnet of CMS
LoDo
It is not connected to a meeting (Joining meeting failed) if the WebRTC client is in the same subnet as interfaces of the Cisco Meeting Server. From other subnets it is connected.
Anurag Srivastava
If it is working with other subnets probably its not a CMS issue.
What exactly happens when you press the Join call?
Did you collected the logs and get any error message?
Probably you can open a TAC case to isolate the issue.
Please rate if it is helpful...
