CMS API configuration tool.
Evgeni Fedotov
New version 1.9.1 of CMS API Configurator application has been released.
Version 1.9.1:
  • Collect CMS System Backup
  • Bug fixes.
You can read information, watch the demo video, download the tool here:
https://cmsapiconfigurator.web.app
11 Replies 11
Evgeni Fedotov
Hello everyone,
New version 1.4 of CMS API Configurator application has been released: http://cmsapiconfigurator.web.app
Version 1.4:
  • CMS API collection has been adjusted with reference version 2.7.
  • Adding API responses into the beginning of the result output window. Latest API responses are always on top in the output window.
  • Bug fixes.
Version 1.3:
  • New features in short video: https://cmsapiconfigurator.web.app/videos
  • Fetching existing setting from the server and populating parameters into the table by pressing "Get existing settings" button if a selected method is "Modifying".
  • Quick copying the desired ID to the clipboard by clicking the left button mouse in the result output window.
  • Bug fixes.
Evgeni Fedotov
New version 1.5 of CMS API Configurator application has been released.
With version 1.5 you can now:
  • Add new CMS servers in tabs.
  • Create and Modify coSpaces from Excel file at coSpaces Bulk method.
  • Export API configuration to JSON or Excel files.
You can read information, watch demo video and download the tool here:
Georg Kehrer
Level 4
Level 4
Dear All
Has anyone install the APi Tool under Linux ? how can I install that?
under Windows is it running well, but I have only a jumphost with WIN2012 at Customer site , and under WIN2012 is not running.
Thats the reason I have tried under Linux.
Any Feedback Help appreciated.
Best Regards
Georg
Hello Georg,
Run the app like any other executables on Linux:
Open the terminal app
cd into a folder with the app
make the app executable:
chmod +x CMS\ API\ Configurator
and run the app with prefix ./ like that:
./CMS\ API\ Configurator
Linux version has a GUI interface the same as windows or mac, thus you have to be in GUI desktop on Linux.
I'm going to test the app on Windows 2012R2 Server today and let you know the outcome.
Tested on newly installed Windows 2012 R2 Server. The app is working fine!
Hello
Thanks for the fast feedback.
the tool is now running under Lunix, was a problem with GLIBC 2.29.
under WIN2012R2 I have the errors message --> see screenshot.
Which additional Software could be missing on my WIN2012R2 ? any Ideas, what is required?
Thanks for your help.
Best Regards
Georg
No additional software is required. It's working on fresh installed windows 2012 R2 and on my windows AD server (2012 R2 as well) which is 5 years old.
Looks like this error is related only to your particular PC.
Try to set Compatibility mode to windows 8 for the exe file, check policies, antivirus software.
Evgeni Fedotov
New version has been released.
Version 1.6:
  • BULK operations have been reworked. The app is using async lib now to make simultaneous requests to CMS for BULK operation.
  • CMS API collection has been adjusted with reference version 2.8.
  • Bug fixes.
Evgeni Fedotov
New version 1.7 of CMS API Configurator application has been released.
Version 1.7:
  • CMS API collection has been adjusted with reference version 2.9 (cameraControl, coSpaceTemplates, accessMethodTemplates, ldapUserCoSpaceTemplateSources and etc.)
  • The App has been converted from a "one file" to a "one folder" app to fix the start delay.
  • Bug fixes.
Evgeni Fedotov
New version 1.8 of CMS API Configurator application has been released.
