cms bridge loopback
chet581
Running CMS 2.9.3
Would anyone know how to enable video loopback. When one participant dials into the bridge and connects to a cospace they don't see themselves.  The Codian bridge allows for that ... great for testing A/V on our bridge.
Thank you.
b.winter
There is no such feature in CMS. The only thing is the self-view option in the meeting. But I guess, this isn't what you want.
Also: Why do you think, just because product x has this feature, CMS also has to have it too?
They are two different product, which have nothing to do with each other. So, I personally wouldn't expect that both share the same feature set.
If you think, you need this feature, then talk to your Cisco AM or open a feature request (and no, the forum isn't the right place to open a feature request)
Thank you for confirming .. If I was the developer I would have added that feature out of the box .. makes sense for customers to use and loopback troubleshooting is very valuable in all areas ... Another feature that would have been nice to bring over from the codian was the number of layout options.   They are very limited ... Roger going via the feature request process .. Appreciate the feedback. Have a great day.
b.winter
No problem.
And yes, some of the features would be helpful for testing.
Please rate a reply as "accepted solution", if the question was answered.
