CMS layout restriction
NEUNG HWI KIM
Hello.
I have deployed CMS v2.0.11 and I think there is some layout issues on CMS.
The layouts which are equal 16 and equal 25 doesn't show all the participants video.
I have tested with 16 end-points connected to a same room, and it only shows 12 videos in one screen.
(H/W Codecs, WebRTC clients are joined in one room.)
Is there any bug reports or restrictions on the layouts?
Patrick Sparkman
There are no restrictions that I'm aware of, can you confirm that the layout used is "all equal"?
What are the names for the different screen layouts?
Hi Patrick,
Thanks for your reply. We have tried with ''all equal sixteenths" and "all equal twenty fifths'.
But it only presents up to 12 participants in the screen.
Could you check about this problem?
Following on the same point please ... is that resolved already ... i have a client request for 16 Equal streams so just wanted to confirm before proceeding
Tarek
I don't know Tarek, never tested it myself.
