CMS LDAP Sync via PowerShell
tormenteddave
Since LDAP doesn't sync automagicaly, I'm trying to write a PowerShell Script that will run and and send a Post to the server to kick off the sync.  My issue is I'm getting a 401 unauthorized.  I'm assuming its the "Username/Password" isn't what the API is expecting so its it failing?   I do have a user ldapsync that has api rights.
ErrorMessage: Invoke-WebRequest : The remote server returned and error: (401) Unauthorized.
Below is my code (go easy, this is my first PowerShell script).
Set-StrictMode -Version Latest
[Net.ServicePointManager]::SecurityProtocol = 'Tls12'
$ErrorActionPreference = "stop" $Body = @{ Username = 'ldapsync' Password = 'syncme' } $LoginResponse = Invoke-WebRequest 'https://CMSFQDN:447/api/v1/ldapSyncs' -Body $Body -Method Post
tormenteddave
I used this and finally got it to work, not super secure but it works.
[System.Net.ServicePointManager]::ServerCertificateValidationCallback = {$true}
$ErrorActionPreference = "Stop"
$username = "ldapsync"
$password = "syncme"
$pair = "${username}:${password}"
$bytes = [System.Text.Encoding]::ASCII.GetBytes($pair)
$base64 = [System.Convert]::ToBase64String($bytes)
$basicAuthValue = "Basic $base64"
$headers = @{ Authorization = $basicAuthValue }
$url = 'https://CMSFQDN:447/api/v1/ldapSyncs/'
Invoke-WebRequest -uri $url -Headers $headers -Method Post -Body $Body
tormenteddave
