CMS mediaProcessingLoad discrepency
Jason Neurohr
Hi All,
I have two Acano X3 servers with which I am regularly polling the /api/v1/system/load API node to retrieve the mediaProcessingLoad value.
According to the Load Balancing Calls Across Cisco Meeting Servers White Paper, the X3's have a maximum load limit of 250,000. (https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/White_papers/Load-balancing-calls-across-Meeting-Servers-2-3-white-paper.pdf, p.g. 7)
However, I find with these X3's which are heavily utilised, that the returned value can peak significantly over the 250,000 number, nearing 300,000. Is the documentation wrong, or the API returning the wrong value? Does anyone else see this?
The version running on the X3's is 2.2.8.
Jason
Jason Neurohr
To comment further, we are seeing utilisation going even higher, upwards to 360,000.
Jason
