11-21-2017 04:57 AM - edited 03-18-2019 01:38 PM
We are trying to create CoSpaces and would like to use GivenName.SurName as CoSpace URI. Unfortunately this Fails due to: Duplicate CoSpace URI (Error 400 Bad request ), in the Event log: LDAP sync: not all URIs are unique (first clash: 'GivenName.Surname')
Only when appending something to the URI, for example: GivenName.SurName.WhatEver it works fine.
So it seems that there is some (hidden) requirement, does anybody know any details about that or a way around that?
best regards and thanks,
Solved! Go to Solution.
11-21-2017 08:02 AM
11-21-2017 06:26 AM
Someone already asked something similar in the past, can't recall the name of the thread, but yes, that is a limitation, they need to be unique and I don't know of any way around that (aside from using a value that is unique for each user in your LDAP).
11-21-2017 07:00 AM
The Problem is not that SIP uri values have to be unique, that is quite understandable, the "strange" part is that it is not possible to create a space (Just one space, no other spaces created) via auto creation of spaces during user Import using the $mail$ variable (using this since this is already nearly guaranteed to be unique). Adding any string to the ldap mapping seems to be mandatory. For example, $mail$ is in most cases/test case just GivenName.Surname@example.com:
CoSpace URI Mapping: $mail|'/@example.com//'$ does not work
CoSpace URI Mapping:$mail|'/@example.com//'$1 works fine
11-21-2017 08:02 AM
