06-02-2018 08:01 AM - edited 03-18-2019 02:09 PM
We have enable webbridge in CMS and publish by expressway. Everything works fine except in iPhone. Documentation say meeting app dont work through expressway so the only option is use browser with webrtc support. No problem in windows and Android, but in IOS al browser try to use the meeting app. Is there any browser in IOS which support the meeting app web client? Or is there any or her solution?
thanks in advance
06-02-2018 11:42 AM
Hi there
Please check this and see that helps you.
CSCvi32490
Symptom:
When user joins as guest using CMS 2.3 Webbridge using Internet Explorer or Safari (any browser that allows Cisco Meeting App to be cross-launched), the link to download CMA client doesn't appear.
Conditions:
Any browser that allows cross-launching Cisco Meeting App when using with CMS 2.3 Webbridge
Workaround:
Revert to previous CMS 2.2 version or if keeping CMS 2.3, use Chrome browser.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
06-02-2018 12:12 PM
Hi Rath,
unfourtanly, this is not the case. The problem is: cma application dont work through expressway. So the only way is use webrtc supported browsers like Chrome, but even Chrome dont work in IOS. The answer is: Is there any browser in IOS which works as cma client itself ( not only ask me to install the app)?
thanks
07-05-2018 05:33 AM
Hello Carlos, you say: "Documentation say meeting app dont work through expressway". Can you tell me in which documentation you found this?
Thx, Geert
07-05-2018 03:05 PM
11-12-2018 10:15 AM
I´m experiencing similar situation using CMS 2.4 and Expressway 8.11.1 acting as reverse proxy. I cannot join a meeting as guest using iPhone. The Safari presents a message to open CMA App for Desktop and launch the App but don´t join. And if I copy the link and paste directly at the CMA App it doesn´t join either.
Chrome works fine on windows (both login and guest conenction).
Any ideas?
11-12-2018 10:34 AM
11-12-2018 11:16 AM
11-13-2018 11:01 AM
Elter,
Do you have a CMS Edge deployed also? iPhone does not support WebRTC, and when they receive the link on an iPhone, it opens a browser, and then after entering their name, and hitting Join, it tries to open the Cisco Meeting App, which will need to find the SRV _xmpp-client._tcp.domain publicly that points to CMS Edge. Currently Expressway does not support XMPP used by CMA. If you don’t have a CMS edge server, it is not going to be possible to have iPhones join as guests using the Join URL.
In order to get iPhones to be able to click a link, they will need come in as a XMPP guest client. That is why you would need to configure a CMS Edge server with a load balancer and trunk to CMS Core.
https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/Deployment_Guide/Version-2-3/Cisco-Meeting-Server-2-3-Single-Split-Server-Deployment.pdf, page 23, section 2.4.1
Hope this answers your question.
Shashank
09-26-2019 07:20 AM
Hi Shashank,
is the limitation you mentioned about iPhone still valid for CMS 2.7 with Expressway 8.11.4 (no CMS edge)? as I'm using this setup and iPhones can't join at all with an message "Lost connection to server attempting reconnect".
or if anyone faced the same please let me know
11-13-2018 02:01 AM
We have CMS Core and Edge solution implemented and working fine with CMA on iPhone and any other devices like MAC or windows.
