03-09-2011 09:04 PM - edited 03-17-2019 10:13 PM
hello,
1. cannot register by add device manually while auto reg is ok
2. ip phone connecting to codec cannot display telepresence screen (codec cannot detect ip phone)
3. there is no WebEx config option on cts manager server (License ?)
Any tips will be appriciated
Solved! Go to Solution.
03-12-2011 09:17 AM
Manually register will work if you have configured the correct device type, codec mac address and DN number for both codec and ipphone.
Make sure you have the right Phone Service applied to the ipphone for the xml interface and make sure the Authentication Server url on the ipphone is pointing to the codec.
What version of TP Man are you using?
03-09-2011 11:22 PM
Updated
2. ip phone connecting to codec cannot display telepresence screen and Room phone status is not ok
3. there is no WebEx config option on cts manager server , caused by CSCtj81002 Bug, but how can I get the script configPolicyParamUpdates.sh ?
03-12-2011 09:17 AM
03-13-2011 05:36 PM
Thanks for reply, manual register is caused by incorrect MAC, and phone displayed telepresense screen after register successfully.
issue remained is the CTS Manager CSCtj81002 Bug
the version information
| SKU | Hostname | IP Address | MAC Address | License MAC Address | Hardware Model | Software Version | OS Version |
| CTS-MAN1.7 | hztp-ctsm | e4:1f:13:68:85:88 | E41F13688588 | 7835I3 | 1.7.2.0 (236) | UCOS 4.0.0.0-31 |
