codec not regstred with the ISDN Link
Shy Solenko
HI,
after pairing the codec with the isdn link and configure it (BRI,EURO), when i try to make call, the call failed and i get message "codec not registred with the ISDN link"
How can i fix it?
Shy
6 Replies 6
Dharmesh Nandoria
What is codec version and ISDN link version , If you are using 5.x for codec and IL 1.0 for link then I will suggest to upgrade codec to TC 6.x and link to IL 1.1.
Error is related to pairing issue , check xsta sys state , you shoud get following if pairing is working .
*s SystemUnit State Status: OK
*s SystemUnit State StatusCode: OK
*s SystemUnit State StatusText: ""
*s SystemUnit State H320Number: "xxxxxxxxx"
*s SystemUnit State MaxNumberOfCalls: 3
*s SystemUnit State NumberOfActiveCalls: 0
*s SystemUnit State NumberOfSuspendedCalls: 0
*s SystemUnit State NumberOfInProgressCalls: 0
*s SystemUnit State PairingStatus: "Paired" #####
*s SystemUnit State PairingStatusText:
Kind regards,
Dharmmesh
Im using 6.0.1 ad 1.1
and i see this errors:
ERROR:
ISDN Link status
The link status is OKWithW: BRI1: [L1 Alarm] BRI3: [L1 Alarm] BRI4: [L1 Alarm].
any one?
BRI 1, BRI3 an BRI4 is down , Check it from service provider end .or de activate from configuration to make text call @ 128 K.
Kind regards,
Dharmmesh
Hi Dharmesh,ף
Thanks!
I will check today with the provider if the BRI lines are Ok.
I didn't understood what you saying about deactivate to make text call@128 K. What it will give me and how to do it?
thanks,
Shy
hi
i have also this problem with BRI (the same BRI status)
did you fix it
regards
