codec plus with p60
salem
We connected the Camera P60 to the Codec Plus using a 10-meter HDMI cable, It says the cable is too long or the signal is weak. while we connect directly P60 to the TV with the same cable and has picture.
Do you have any solution for connecting p60 to codec plus with HDMI cable 10 meter?
Which HDMI cable will work?
regards,
Jonathan Schulenberg
Use an active optical cable or dedicated extender product such as FSR Digital Ribbon Cable or SCT RC5-P60, respectively. The fiber cables are fragile though, so be careful and follow the instructions during installation.
Thanks, but this camera with the same normal cable working with SX80. and working directly to TV.
Is this issue from codec plus?
Weak connector?
