06-11-2018 01:40 PM - edited 03-18-2019 02:10 PM
I have a customer with three telepresence rooms. One has a SX80/Touch 10, and two have the Spark Room Kit Plus/Touch 10 units. I am looking to add the ability to turn the Displays on/off, and also change the mute status indicator on the in-ceiling Shure MXA910 microphones. Will I need to completely create the Touch 10 pages: Global, Home Screen, and In-Call, or will what I create be added to the existing interface? I've already been working with my Crestron Programmer, and he has provided me with the Widget IDs that I need to insert.
Solved! Go to Solution.
06-11-2018 09:16 PM
You don't need to totally recreate the whole screen, you would just add another button/page to the existing ones to trigger the functionality/widgets you require. The CE9.3 Room Customisation Guide shows some examples of a simple on/off switch/widget on page 18.
Please remember to mark helpful responses and to set your question as answered if appropriate.
06-11-2018 01:56 PM
It will be an addition to the existing GUI.
Take a look at this document, it's quite thorough: https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce90/sx-mx-dx-room-kit-in-room-control-guide-ce90.pdf
Hope this helps!
06-11-2018 02:14 PM
PJMack,
Thanks so much for the help. I'll take a good thorough look over the document you included. At first glance, it's a plethora of information that I was unaware of before. Looks like I'll be able to make my customer happy after all.
Michael
06-11-2018 06:46 PM
Don't forget you can use HDMI CEC to turn the displays off and on automatically (when the unit comes in/out of standby, it sends the appropriate on/off command to the display - just enable the setting on both the display and codec). Much more intuitive than a manual on/off button.
06-11-2018 09:16 PM
