01-12-2017 06:35 AM - edited 03-18-2019 12:47 PM
I have a Cisco Telepresence sx10 registered to a CUCM 11.5. The telepresence works fine internally with devices registered with CUCM.
So I configured Expressway-C/E. I created a DNS zone which gives access to calls at any domain. I tested the configuration which works fine with SIP TCP.
I installed a public certificate on Expressway-Edge, which is correct and trusted as i tested it. Somehow I cannot make sip tls calls to other SIp tls domains which are verified by the way. I am testing with Skype for Business federated sip tls domains.
When I make outbound calls from the logs in the Expressway-Edge i get:
It seems like the request goes for SIP not SIP TLS. My telepresence is configured for SIP TCP connection with my CUCM. The CUCM is configured with SIP trunk with Expressway-C. The traversal zone between Expressway-c and E is configured with TCP
When I make Inbound calls from Skype for Business client of the other domain I get:
404 Not Found
ms-diagnostics: 1034;reason="Previous hop federated peer did not report diagnostic information";Domain="albcontrol.al";PeerServer="edgee.albcontrol.al";source="sip.voice.gov.al";OriginalPresenceState="0";CurrentPresenceState="0";MeInsideUser="Yes";ConversationInitiatedBy="0";SourceNetwork="0";RemotePartyCanDoIM="No"
sx10@albcontrol.al is the Directory URI of the telepresence which is configured in Directory number in CUCM.
Do I need to have this DNS record externally? It didn't seem to be on the requirements.
What else am I missing here?
Julian
01-12-2017 09:44 AM
If a device is registered to CUCM, it will use CUCM for ALL calls, in such scenario, you would need EXP-C/E to configure B2B, or use the device as standalone.
01-12-2017 11:26 PM
Hi Jaime,
Can you please advice on how to use the device as standalone? Do I have to Nat SIP traffic to the Device's Ip or to use a public Ip for the Device? On the other hand, Should I use a SIp address or direct ip?
What record on external DNS do I have to configure?
02-01-2017 03:23 PM
There are plenty of threads on how to configure one of these types of devices as a standalone endpoint - do a search for "sx20 standalone" and you will see many threads.
Note: Your question would be better placed in the TelePresence section of the forums where these devices are more actively discussed than in the Video Over IP section you've posted in - I'd suggest, if the above hasn't answered your query, that you move your discussion over there (you can do this by editing your original post and changing the category at the bottom).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
