Connect to calls outside my VCS-E from the Cisco Meeting Web App
Scott Nieto
Is it possible to connect from my Cisco Meeting Web App to aliases/spaces which are not registered on a VCS-C but are remote and neighbored via a VCS-E?
We can connect via CODEC to aliases/spaces which are registered with a VCS-E that is neighbored to our VCS-E, but we can't connect to those same spaces/aliases through the Web App.
Yes you should be able to connect remote rooms / Meetings you should check your outboung calls configuration on your CMS and Search rules on both EXP-C and EXP-E
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Please let me know
Carlo
Carlo,
Thank you. It is a dial plan issue.
Scott
