Connecting PS3 to C40
gubadman
Level 3
Level 3
Hi all,
Is it possible to connect a Sony PlayStation 3 to a Cisco C40 using the Video Input Source 2 HDMI connection?
When I try this I just get a black screen when I try and do a presentation, though it does show that the port is getting input:
*s Video Input Source 2 Resolution Height: 1080
*s Video Input Source 2 Resolution Width: 1920
*s Video Input Source 2 Resolution RefreshRate: 60
*s Video Input Source 2 Resolution FormatType: Digital
*s Video Input Source 2 Resolution FormatStatus: Ok
Guy
Tomonori Taniguchi
You need to use external device to remove protection signal.
For example GAME SWITCH…
Tomonori Taniguchi
Marius Nedregaard
Just to fill out Tomo`s answer.
PS3 use HDCP ( http://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection ) you need something that strips HDCP of the stream.
Many home cinema receivers with HDMI capabilites does this.
//Marius
