Showing results forĀ
Search instead forĀ
Did you mean:Ā
CS-KITP60-K9 Cable Length recommendation
maneesh83
We need install  CS-KITP60-K9 to our customer. Customer required to place the Codec on overhead ceiling which is approximate Ten meter far from the Camera.Any one please suggest me the below.
What is the Cisco recommended HDMI and Ethernet cable length between the Codec and Camera?
What is the Cisco  recommended HDMI cable length between Codec and table PC for content sharing ?
What is the Cisco recommended Table Microphone cable length between Codec and microphone?
zeuscyril
Level 4
Level 4
hi
for network its basic network length 90m
for hdmi  my recommendation is use Ethernet to hdmi converters if the length is more for HDMI connection. because in camera the HDMI need to send power as well so my recommendation is use converters aten brand its availble.
for microphone normally it comes with 7.5m length and additionally you can add one more 7.5m but you need to buy that additional connector cable.
