CTS500-CUBE-Cisco TP Server, video connection fails
MIKKO JARVELA
We are trying to configure interoperability with TelePresence Server (8710) to our TP installation. TP Server is located in our 'public' network as external callers are connected to Codian MCU via VCS ExpressWay and VCS Control.
Internal TP network is connected via Cisco CUBE to TP server ie.
TPNetwork -----CUBE----VCS Control----TP Server(8710)
CUBE is configured as recommended for TP Intercompany calls, but result is:
CTS500->TP Server: No Video, audio only call
TPServer-> CTS500: Starts with video & audio, but video dropped after 1 sec. Audio is more or less hissing and whistling sounds (codec incompatibility perhaps?).
So my question is, what is recommended config for CUBE to get this work?
IOS version is latest 12.4T maintenance release.
CTS500 is running 1.6.7(4212), CUCM 7.0.2 and TP server 2.1(1.33) (Build 9.4(1.33))
Best Regards,
Mikko
7 Replies 7
gogasca
Level 10
Level 10
Hi Mikko,
Can you post your configs?
I think theres a thread here from Nick which he posted a sample config for TP calls that may help.
Once you post your config please do a:
debug voice ccapi inout
debug ccsip messages
Attached file contains CUBE config and debugs as you advised. Problem appears only with calls to dial-peer 4. Calls between two TP CUCMs (other two dial-peers) are not affected.
SIP Trunk @ VCS is configured as below...
/Mikko
Zones Zone 4 Name: CiscoCUBE
Zones Zone 4 HopCount: 15
Zones Zone 4 H323 Mode: Off
Zones Zone 4 SIP Mode: On
Zones Zone 4 Type: Neighbor
Zones Zone 4 Neighbor Registrations: Allow
Zones Zone 4 Neighbor H323 Port: 1719
Zones Zone 4 Neighbor AdvancedMediaGateway Mode: Off
Zones Zone 4 Neighbor Interworking SIP EmptyInviteAllowed: On
Zones Zone 4 Neighbor Interworking SIP Audio DefaultCodec: G711u
Zones Zone 4 Neighbor Interworking SIP Video DefaultCodec: H263
Zones Zone 4 Neighbor Interworking SIP Video DefaultBitrate: 384
Zones Zone 4 Neighbor Interworking SIP Video DefaultResolution: CIF
Zones Zone 4 Neighbor Interworking SIP Search Strategy: Options
Zones Zone 4 Neighbor SIP Port: 5060
Zones Zone 4 Neighbor SIP MediaRouting Mode: Auto
Zones Zone 4 Neighbor SIP Transport: TCP
Zones Zone 4 Neighbor SIP TLS Verify Mode: Off
Zones Zone 4 Neighbor SIP Authentication Trust Mode: On
Zones Zone 4 Neighbor SIP SearchAutoResponse: Off
Zones Zone 4 Neighbor SIP Encryption Mode: Auto
Zones Zone 4 Neighbor SIP Poison Mode: Off
Zones Zone 4 Neighbor SIP UDP BFCP Filter Mode: Off
Zones Zone 4 Neighbor SIP Duo Video Filter Mode: Off
Zones Zone 4 Neighbor SIP SDP Attribute Line Limit Mode: On
Zones Zone 4 Neighbor SIP SDP Attribute Line Limit Length: 130
Zones Zone 4 Neighbor SIP MIME Strip Mode: Off
Zones Zone 4 Neighbor SIP MIME Strip SDP Part
Zones Zone 4 Neighbor SIP UPDATE Strip Mode: Off
Zones Zone 4 Neighbor SIP ProxyRequire Strip List
Zones Zone 4 Neighbor SIP Record Route Address Type: IP
Zones Zone 4 Neighbor Peer 1 Address: 1.1.169.25
Zones Zone 4 Neighbor Peer 2 Address
Zones Zone 4 Neighbor Peer 3 Address
Zones Zone 4 Neighbor Peer 4 Address
Zones Zone 4 Neighbor Peer 5 Address
Zones Zone 4 Neighbor Peer 6 Address
Zones Zone 4 Neighbor ZoneProfile: CiscoUnifiedCommunicationsManager
Zones Zone 4 TraversalClient Authentication
Zones Zone 4 TraversalClient H323
Zones Zone 4 TraversalClient SIP TURN Server
Zones Zone 4 TraversalClient SIP TLS Verify
Zones Zone 4 TraversalClient SIP Poison
Zones Zone 4 TraversalClient Peer 1
Zones Zone 4 TraversalClient Peer 2
Zones Zone 4 TraversalClient Peer 3
Zones Zone 4 TraversalClient Peer 4
Zones Zone 4 TraversalClient Peer 5
Zones Zone 4 TraversalClient Peer 6
Zones Zone 4 TraversalServer Authentication
Zones Zone 4 TraversalServer UDPProbe
Zones Zone 4 TraversalServer TCPProbe
Zones Zone 4 TraversalServer H323 H46019 Demultiplexing
Zones Zone 4 TraversalServer SIP TLS Verify Subject
Zones Zone 4 TraversalServer SIP Poison
Zones Zone 4 ENUM
Zones Zone 4 DNS Interworking SIP EmptyInviteAllowed: On
Zones Zone 4 DNS Interworking SIP Audio DefaultCodec: G711u
Zones Zone 4 DNS Interworking SIP Video DefaultCodec: H263
Zones Zone 4 DNS Interworking SIP Video DefaultBitrate: 384
Zones Zone 4 DNS Interworking SIP Video DefaultResolution: CIF
Zones Zone 4 DNS SIP TLS Verify
Zones Zone 4 DNS SIP SearchAutoResponse: Off
Zones Zone 4 DNS SIP Poison Mode: Off
Zones Zone 4 DNS SIP UDP BFCP Filter Mode: Off
Zones Zone 4 DNS SIP Duo Video Filter Mode: Off
Zones Zone 4 DNS SIP SDP Attribute Line Limit Mode: Off
Zones Zone 4 DNS SIP SDP Attribute Line Limit Length: 130
Zones Zone 4 DNS SIP Record Route Address Type: IP
Hi again,
While looking running configuration more closely and comparing it to another running CUBE, that 12.4(22)T does not support "pass-thru content sdp" configuration in sip voice service. 12.4(22)YB does and that is version which I use in another one. Could this be a reason to non working call to TelePresence Server???
Don't ask why I decided to use 12.4(22)T instead of YB - answer is too obvious, I was too lazy to change IOS
/Mikko
More investigation... This might be related to CSCth61759??? If yes, is this bug integrated in 15.1(3)T. Bugtoolkit says that it is fixed in 15.1(2.13)T, but no mention about normal CCO releases.
/Mikko
Regarding CSCth61759 , look to CCO URL  :   http://www.cisco.or.at/en/US/docs/ios/15_1/release/notes/151TCAVS.pdf
Thanks Hans,
I'll upgrade to 15.1(3)T and retry.
Mikko
Upgraded to 15.1(3)T... works like dream
Thanks for help!
/Mikko
