cucm 12.5.1 snmp v3 configuration for telepresence video endpoints.
I have cucm 12.5.1 in which i have added webex room kit plus as a device. now i want to configure snmp v3 for it, but i am not able to see any snmp dashboard for the snmp v3 configuration for that device.
how can i configure snmp v3 for that.
Any help is appreciated!!!!
Jonathan Schulenberg
Login to the endpoint and set it there under Network Services. CUCM only has a subset of the config options supported by the device.
If you mean that you want to configure the webex room kit plus  from the CUCM , you can do it from phone page > Product Specific Configuration Layout but before that from the same page you should navigate to Miscellaneous > General Settings and choose the configuration control role is “Unified CM and Endpoint “or “Unified CM” only if you need that, then configure the kit plus username and password which were configured from the endpoint itself, however room kit plus even the latest versions are not supported SNMP v3 it supports only SNMP V1/V2
