04-14-2014 04:11 PM - edited 03-18-2019 02:52 AM
I want to understand the call flow from CUCM to VCS to VCS-express and vice versa. Like to make a video call from Cisco IP Phone to endpoint out of the organization, the call flow will be as the following:
From the IP Phone dial: abc@external.com
The address will match SIP Route Pattern *@external.com to SIP trunk to VCS. In VCS search rule to traversal zone … etc.
Please help me to complete the call flow and correct me if I am wrong.
04-14-2014 05:16 PM
That is the correct call flow. You will have a SIP trunk from CUCM to VCS IP and also zones and search rules on the VCS to call back.
Check this guide out: http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Cisco_Unified_Communications_Manager_Deployment_Guide_CUCM_8_9_and_X7-2.pdf
04-14-2014 05:25 PM
thank you for your reply
I have read this document before, it is for CUCM to VCS only no VCS express
04-14-2014 05:27 PM
Correct, use the above document for calls from CUCM to VCS.
For VCS to VCS Expressway, use this document:
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Basic_Configuration_Control_with_Expressway_Deployment_Guide_X7-2.pdf
04-24-2014 07:18 AM
I think I need this only with version 7 with 8 I should integrate VCS with expressway in other way.
