CUCM to VCS issue
born.jason
have a problem with dialing from CUCM to VCS (7.1). The othr way is working fine.
I have played with Search rules and Transforms but it will not work. The End device on VCS is a SIP device.
Here are the log:
Sep 21 11:14:26    tvcs: Event="Call Rejected" Service="SIP" Src-ip="10.234.40.5" Src-port="5060" Src-alias-type="SIP" Src-alias="sip:60976@10.234.40.5" Dst-alias-type="SIP" Dst-alias="sip:50555@10.224.35.249:5060" Call-serial-number="bdb3272c-03cc-11e2-bef9-0010f3249b3a" Tag="bdb32808-03cc-11e2-bbef-0010f3249b3a" Detail="Not found" Protocol="TCP" Response-code="404" Level="1" UTCTime="2012-09-21 09:14:26,549"
Sep 21 11:14:26    tvcs: Event="Search Completed" Service="SIP" Src-alias-type="SIP" Src-alias="60976@10.234.40.5" Dst-alias-type="SIP" Dst-alias="sip:50555@10.224.35.249:5060" Call-serial-number="bdb3272c-03cc-11e2-bef9-0010f3249b3a" Tag="bdb32808-03cc-11e2-bbef-0010f3249b3a" Detail="found:FALSE, searchtype:INVITE" Level="1" UTCTime="2012-09-21 09:14:26,549"
Sep 21 11:14:26    tvcs: Event="Call Attempted" Service="SIP" Src-ip="10.234.40.5" Src-port="5060" Src-alias-type="SIP" Src-alias="sip:60976@10.234.40.5" Dst-alias-type="SIP" Dst-alias="sip:50555@10.224.35.249:5060" Call-serial-number="bdb3272c-03cc-11e2-bef9-0010f3249b3a" Tag="bdb32808-03cc-11e2-bbef-0010f3249b3a" Protocol="TCP" Auth="NO" Level="1" UTCTime="2012-09-21 09:14:26,539"
Sep 21 11:14:26    tvcs: Event="Search Attempted" Service="SIP" Src-alias-type="SIP" Src-alias="60976@10.234.40.5" Dst-alias-type="SIP" Dst-alias="sip:50555@10.224.35.249:5060" Call-serial-number="bdb3272c-03cc-11e2-bef9-0010f3249b3a" Tag="bdb32808-03cc-11e2-bbef-0010f3249b3a" Detail="searchtype:INVITE" Level="1" UTCTime="2012-09-21 09:14:26,539"
Could anybody help?
Jason
jason,
the desitnation is coming as "50555@10.224.35.249:5060"so that ip should be 10.224.35.249
what you have to change here is change the search rule to.
source         any
Regex         (.*)@10.224.35.249((:|;).*)?
action          replace
string           \1@10.224.35.249
the SIP AOR is  50555@10.224.35.90 so i think it should work after making the chnges to search rule.
rgds,
Alok
8 Replies 8
Patrick Pettit
HI Jason.  The call inbound from CUCM is looking for: 50555@10.224.35.249:5060?  Is the system registered locally to VCS?  If the system is registered at: 50555@domain.com on VCS control, you have transform to convert this call to that domain?
May we see the search history of the entire call?
VR
Patrick
Alok Jaiswal
Hi Jason,
404 not found means VCS is not a ble to find the endpoint sip uri.
have you ensured that you have created a transform or search rule to strip the ip and add domain.
you need to create a search rule for incoming where you would stripping the ip and chaning it to VCS sip domain
source         any
action          replace
string           \1@vcs sip domain\2
ensure the search rule has necessary priority set.
Thanx
Alok
Hmm i have tried it but i only get calls working from the registered EX90 to the CUCM but not the other way.
CUCM: 10.234.40.5
VCS: 10.224.35.249
So the search rule should look like this from you?
source         any
Regex         (.*)@10.234.40.5((:|;).*)?
action          replace
string           \1@10.224.35.249\2
Or have to be the domain instead IP? but i tried both...
I have tried you search rule but the same in the log... Is the EX90 wrong registered maybe?
Protocol    SIP
Node    Local VCSC Zone
Serial number    d2c77e66-03d5-11e2-93e1-0010f3249b3a
Authenticated    False
Creation time    2012-09-21 12:19:27
Duration    16 minutes 52 seconds
Seconds since last refresh    0
Seconds to expiry    60
Vendor information    TANDBERG/516 (TC5.1.3.292001)
AOR    50555@10.224.35.249
Contact    sip:50555@10.224.35.19:57093;transport=tls
Instance    ""
Public GRUU    sip:50555@10.224.35.249;gr=urn:uuid:00000000-0000-0000-0000-005060075d59
jason,
source         any
action          replace
rgds,
Alok
Sorry the 10.224.35.90 was wrong.... i changed it...
I will check your search rule.
Or add the domain to the SIP URI on the SIP Settings page on your EX90 and convert to domain.  Either way should work, but it seems the EX90 doesn't have @domain in SIP URI page, and its registering @ip since it isn't listed.
VR
Patrick
Ok, changed the rule to yours and got a busy tone on the phone and a call loop in the log:
Sep 21 13:09:10    tvcs: Event="Call Rejected" Service="SIP" Src-ip="10.234.40.5" Src-port="5060" Src-alias-type="SIP" Src-alias="sip:60976@10.234.40.5" Dst-alias-type="SIP" Dst-alias="sip:50555@10.224.35.249:5060" Call-serial-number="c510cb2c-03dc-11e2-93ff-0010f3249b3a" Tag="c510cc08-03dc-11e2-8277-0010f3249b3a" Detail="Loop Detected" Protocol="TCP" Response-code="482" Level="1" UTCTime="2012-09-21 11:09:10,901"
changed the rule to
source         any
action          replace
Target is localZone
and the log shows 404
Sep 21 13:10:24    tvcs: Event="Call Rejected" Service="SIP" Src-ip="10.234.40.5" Src-port="5060" Src-alias-type="SIP" Src-alias="sip:60976@10.234.40.5" Dst-alias-type="SIP" Dst-alias="sip:50555@10.224.35.249:5060" Call-serial-number="f0c927dc-03dc-11e2-a043-0010f3249b3a" Tag="f0c928c2-03dc-11e2-ba27-0010f3249b3a" Detail="Not found" Protocol="TCP" Response-code="404" Level="1" UTCTime="2012-09-21 11:10:24,205"
Any suggestion?
Forgot to remove the \2 . Now its working. In and Out. Thank you very much.
Now the next step ist to register a device or Jabber for Video from Outside.
