CUVC-M and OCS Plugin
Rajesh Revuru
Level 4
Level 4
Guys:
Need some help regarding an issue we are having with OCS plug-in for CUVC-M. When we go to launch an ad-hoc meeting, we are getting "Failed to Join the meeting" error. When used wireshark on CUVC-M server to capture the packets, we are getting a SIP decline message from CUVC-M to MCU. We are using built-in gatekeeper.
Here is the call flow
MCU ----> SIP INVITE ---> CUVC-M
CUVC-M ----> SIP DECLINE ---> MUC
I have a TAC case opened also, TAC engineer said the config looks good, they are also looking, wanted to see if you guys have any ideas
Rajesh Revuru
Level 4
Level 4
Guys:
I had to delete the SIP server on CUVC-M and re-added and change the SIP domain, worked fine.
