Direct VM Access from UCCX
Michael Meyer
Hey Guys
On my CUCM we have setup Direct to VM using the pattern *XXXX
I have a requirement in UCCX to re-direct a call to a Direct VM. Voicemail is Unity Connection.
UCCX cannot send in a call redirect an "*" so the call fails.
I've been able to confrim this by changing the *XXXX pattern to 9XXXX pattern and it is working as expected.
Question: Is there a better way for UCCX to access a drect VM Box?
Cheers
Mike
Michael Meyer
Never mind, I found an elegant solution.
Call redirect to the main VM pilot number and then in then reset the called address to the pilot of the mailbox.
Done and dusted!
