Distributing Voice calls
I have a Voice gateway terminating 2 voice lines( T1-PRI).
On this gate way I have two ethernets.
Is it possible to send all the incomming calls from one T1 out of one ethernet and all the calls form another T1 over other ethernet?
i.e mapping the T1 to ethernet ..
k.poplitz
Level 3
Level 3
I guess you can achieve this, if you employ some policy based routing here. If you identified the destination for both the T1s, then you can define some policies to take the respective Ethernet interfaces.
