07-19-2017
08:31 AM
- last edited on
03-18-2019
01:19 PM
by
NikolaIvanov
hey guys
trying to downgrade from CE8.1.1 to TC.7.9.
when I download the TC file and upload it, it finishes uploading and then I get a error saying :
I need to downgrade from CE8.1.1 to TC software. what am I doing wrong?
kind REgards
07-19-2017 08:39 AM
What model codec is it and what is the filename of the package you are uploading to it?
Justin
07-19-2017 09:26 AM
It's a SX 20.
File name I tried: non crypto: s52011tcnc7_3_9.pkg
File name I also tried: s52010tc7_3_9.pkg
thanks
07-19-2017 09:04 PM
I was just reading the release notes of CE 8.X which says
Downgrading from Collaboration Endpoint Software to TC software is supported.
When downgrading a system paired with a Touch 10 panel from TC to Collaboration Endpoint Software, the Touch 10 panel will be downgraded automatically. We recommend first downgrading from CE8.x to TC7.3.6 or later before downgrading further.
Can u try to TC 7.3.6 and check?
regds,
aman
