dtmf-relay sip-notify
John Cheetley
Level 3
Level 3
Evening Cisco techs,
Having trouble enabling sip-notify
Using CME 3.3 via (C2691-IPVOICEK9-M), Version 12.4(25d), RELEASE SOFTWARE (fc1)
Have registered cisco phones set up in CME
SIP is enabled on router. So is H323
In conf t mode via voice service voip
Upon using dtmf-relay sip-notify I get the error of unrecognised command
If other information is required. Please let me know
9 Replies 9
Terry Cheema
Configure it under your dial-peers.
Hi Terry,
Thanks for your quick response and time
Perhaps I missed something.
Can you please advise of a link for this thanks if that's not too much trouble?
Just go to your SIP dial-peers:
R01#conf t
R01#dial-peer voice XX voip    << XX is you SIP dial-peer
R01(config-dial-peer)#dtmf-relay ?
  cisco-rtp          Cisco Proprietary RTP
  h245-alphanumeric  DTMF Relay via H245 Alphanumeric IE
  h245-signal        DTMF Relay via H245 Signal IE
  rtp-nte            RTP Named Telephone Event RFC 2833
  sip-kpml           DTMF Relay via KPML over SIP SUBCRIBE/NOTIFY
  sip-notify         DTMF Relay via SIP NOTIFY messages
dial-peer voice 555 voip
 destination-pattern 55555
 session protocol sipv2
 session target ipv4:1.1.1.1
-Terry
Evening Terry,
Unfortunately  I only have these options
cme_router(config-dial-peer)#dtmf-relay ?
I have both H323 and SIP enabled as below shows
voice service voip
 sip to sip
This option will be visible under SIP dial-peer, your SIP dial-peer should have following command under the dial-peer:
Thanks Terry for your reply.
That option is under the dial-peer I'm using
sip-ua confirms the service working.
However. When I run sh sip-ua register status.
Comes back advising no lines registered
Just wondering are you using SIP Phones or SCCP Phones?
Could you please post your router CME config as well, please.
It will be much easier to tell once we have a look on the config.
Hi Wilson,
Thanks for your reply. My apologies for my delay
Using SCCP phones thanks
Router CME config attached.
Hi Wilson,
Not to pester you. Just wandering if you have any information re the data I sent  you please?
