02-21-2017 07:16 PM - edited 03-18-2019 12:48 PM
I have an SX20 connected to two displays. All I want is simply see the far end presenter on one screen and the presentation they send on the second screen. I tinkered with the settings to try to do this to no avail. Curiously, while I have Configuration | Video | Monitors set to Dual, when I go to Configuration | System Status | Video, under monitors is says "Single." I attached the config of the Video tab for reference.
Solved! Go to Solution.
02-22-2017 12:37 PM
You need to have the Dual Display option key installed, you can check if this is installed on the System Information page of the web interface under Home. You then need to configure the following options:
In addition to the above, if you want selfview to appear on the second screen, you need set the following as well:
02-21-2017 07:43 PM
Not only do you need to configure the Video > Monitors to Dual (or DualPresentationOnly), buy you also need to tell it which output should be used for what purpose under Output > Connector 1 > MonitorRole: First, and Output > Connector 2 > MonitorRole > Second (or PresenationOnly).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
02-21-2017 07:57 PM
Wayne, I have it setup that way. But still, it insists on showing both the presenter and presentation on the first display. Also, in the LocalLayoutFamily, I tried all the options with the same result. Is there a soecial license needed to run dual display?
02-21-2017 08:11 PM
Is there a special license needed to run dual display?
That will depend on when your SX20 was purchased and what software release you are running.
See my response in thread: SX20 Dual Display Licensing
Wayne
02-21-2017 08:21 PM
It was purchased in 2016 as a spare base unit. The current version is TC7.3.6.ea51021. It doesn't seem like this would be something special, it's so basic. The one thing I do not understand is why it says Monitors=Single when I go to Configuration -> System Status -> Video. Maybe that's a clue? Thanks for the help.
02-22-2017 12:37 PM
