DX80 touch screen is unresponsive - CSCus38877
ogaldona
Beginner
Beginner
Conditions:
Due to hardware issues with the touch controller calibration causes the screen to be unresponsive and can cause phantom touches on the screen.
The phantom touches is what is bugging me since it keeps bringing up the voice menu over and over again. After the upgrade to 8.3.1, two of the three DX80's have this issue and is very distracting. Is anyone else experiencing this? Is there a new workaround besides having to unplug HDMI and rebooting every time?
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCus38877/?referring_site=bugquickviewclick
Wayne DeNardi
VIP Advisor VIP Advisor
VIP Advisor
The only time I experienced the pahntom touches was when the screen was very dirty from greasy fingerprints.
If you device is constantly doing this, even after the reboot, then, as suggested in the bug reference you linked, the best solution is to RMA the unit.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
32 Replies 32
dpetrovi
Conferencing community is for Cisco Webex Meetings Server and Cisco Unified MeetingPlace products and is not observed by DX80 experts. Let me move this post to Telepresence community that supports the product you are using.
-Dejan
Wayne DeNardi
VIP Advisor
Wayne
Wayne
Where do I take the unit to get this fixed and how much is it for the fix?
ogaldona
Beginner
Beginner
I am having to RMA the device. No cleaning would clear this up. Thanks.
Brian Meade
Rising star
Rising star
As a workaround, you can open the unit and disconnect the touch controller.  The touch controller is directly under the HDMI connectors and has 4 ribbon cables going to it.  You can disconnect the 4-pin cable at the top of this board which runs to the main board.  This disables all touch control but allows you to use the unit with mouse/keyboard.
That’s great news now but I ended up selling it after not being able to fix issue. Thank you for your help anyhow:)
Just to update everyone in case people come across this in the future, it doesn't look like the CE code supports keyboard/mouse control.  So you'll have to stay on Android if you want to disconnect the touch controller.
This is the touch controller part number-
SiS9250B0GAX3+SiS9203-LGE 23''_V04
Having problems finding these online anywhere shipping to the US.
We got many DX80 units on the same issue,and no service so cannot RMA. Is there any clue we can fix the issue by hardware DIY ?
The part is only $10 I can purchased locally, if sure can fix the issue by change the part I will try.
The bug details mention a calibration issue so it's difficult to confirm if a hardware replacement of the board will fix.  I may try to replace the board from a working DX80 to test that theory.
I've had some problems trying to find a local source for the board in the US.  Were you able to find the boards somewhere that ships to the US?
It looks to be the same board used in the LG ET83 touch screen.  I believe this is the screen Cisco used in the DX80.
