12-13-2013 04:41 AM - edited 03-18-2019 02:18 AM
My E20 reboots continuously with following error.
Dec 13 16:26:26 (none) main: Received signal SIGSEGV (11) in thread 0x4084d450, TID 1768
Dec 13 16:26:26 (none) main: Illegal memory access at: (nil)
Historical Logs - All.log
Dec 13 16:20:34 (none) main: Thread LedTask has TID 1740
Dec 13 16:20:35 (none) main: FPGA programmed OK
Dec 13 16:20:35 (none) main: Product information
Dec 13 16:20:35 (none) main: Snoopy
Dec 13 16:20:35 (none) main: Board revision: H
Dec 13 16:20:35 (none) main: TE4.1.1.273710
Dec 13 16:20:35 (none) main: SVN Revision 273710
Dec 13 16:20:35 (none) main: Serial number: A1AA19B00158
Dec 13 16:20:35 (none) main: Program audio dsps [1]
Dec 13 16:20:44 (none) osd: WARNING : Cannot parse value [ "" ] in "Config/Video/Selfview" to boolean. Treating it as "false".
Dec 13 16:20:44 (none) osd: WARNING : TState has no desktop set
Dec 13 16:20:47 (none) main: shmemLoadDsp: Program video dsp
Dec 13 16:20:49 (none) main: shmemLoadDsp: Program video dsp finished
Dec 13 16:20:49 (none) video: DSP ID 1
Dec 13 16:20:49 (none) video: Product information
Dec 13 16:20:49 (none) video: Snoopy
Dec 13 16:20:49 (none) video: Board revision: H
Dec 13 16:20:50 (none) video: fsm_procSetup: Open Interprocessor comm devs.
Dec 13 16:20:50 (none) video: shmemdsp: Waiting for arm to init shmem area. (119)
Dec 13 16:20:50 (none) main: Thread persistDb has TID 1757
Dec 13 16:20:51 (none) video: shmemdsp: Waiting for arm to init shmem area. (118)
Dec 13 16:20:51 (none) main: Thread persistDb has TID 1760
Dec 13 16:20:52 (none) main: Thread ShmemRx has TID 1761
Dec 13 16:20:52 (none) main: Thread UhpiRx has TID 1762
Dec 13 16:20:52 (none) main: Thread TimerThread has TID 1767
Dec 13 16:20:52 (none) main: fsm_procSetup: Open Interprocessor comm devs.
Dec 13 16:20:52 (none) main: Thread WatchdogThread has TID 1765
Dec 13 16:20:52 (none) main: Thread WatchdogKickerThread has TID 1766
Dec 13 16:20:52 (none) main: Thread BluetoothGW has TID 1764
Dec 13 16:20:52 (none) main: fsm_procSetup: Initialize data structures.
Dec 13 16:20:52 (none) main: fsm_procSetup: Create all FSM tasks[6].
Dec 13 16:20:52 (none) main: Thread FsmMedia has TID 1769
Dec 13 16:20:52 (none) main: Thread FsmClksync has TID 1772
Dec 13 16:20:52 (none) main: Thread FsmAudioFilePlay has TID 1773
Dec 13 16:20:52 (none) main: fsm_procSetup: Check for system synchronization.
Dec 13 16:20:52 (none) main: Sync startup: Wait for clients to register.
Dec 13 16:20:52 (none) video: shmemdsp: Waiting for arm to init shmem area. (117)
Dec 13 16:20:52 (none) audio: applstart: hello
Dec 13 16:20:52 (none) audio: Product information
Dec 13 16:20:52 (none) audio: Snoopy
Dec 13 16:20:52 (none) audio: Board revision: H
Dec 13 16:20:52 (none) audio: applstart: cpuclock: 294 MHz
Dec 13 16:20:52 (none) audio: applstart: sysid SYSTEM_AUDIO0
Dec 13 16:20:52 (none) audio: Give ourselves high priority!
Dec 13 16:20:52 (none) audio: Initialize the fsm system!
Dec 13 16:20:52 (none) audio: Create and start the fsm tasks!
Dec 13 16:20:52 (none) audio: fsm_procSetup: Open Interprocessor comm devs.
Dec 13 16:20:52 (none) audio: fsm_procSetup: Initialize data structures.
Dec 13 16:20:52 (none) audio: fsm_procSetup: Create all FSM tasks[4].
Dec 13 16:20:52 (none) audio: fsm_procSetup: Check for system synchronization.
Dec 13 16:20:52 (none) audio: registerAndWaitForNotify: Sending id = SYSTEM_AUDIO0(2) (33554432)
Dec 13 16:20:52 (none) audio: Wait for timeout, or incoming message
Dec 13 16:20:52 (none) main: Thread FsmAudio has TID 1771
Dec 13 16:20:52 (none) main: Thread FsmMain has TID 1768
Dec 13 16:20:52 (none) main: Thread ComRouter has TID 1770
Dec 13 16:20:52 (none) main: waitForRegistrationsAndNotify: Registring msg from SYSTEM_VIDEO0(1)
Dec 13 16:20:53 (none) main: waitForRegistrationsAndNotify: Registring msg from SYSTEM_AUDIO0(2)
Dec 13 16:20:53 (none) main: waitForRegistrationsAndNotify: All sync messages received. Notifying all clients.
Dec 13 16:20:53 (none) main: waitForRegistrationsAndNotify: Sync finished!
Dec 13 16:20:53 (none) main: fsm_procSetup: Signal tasks to run create.
Dec 13 16:20:53 (none) main: fsm_procSetup: wait for create(s) to finish
Dec 13 16:20:53 (none) video: fsm_procSetup: Initialize data structures.
Dec 13 16:20:53 (none) video: fsm_procSetup: Create all FSM tasks[6].
Dec 13 16:20:53 (none) video: fsm_procSetup: Check for system synchronization.
Dec 13 16:20:53 (none) video: registerAndWaitForNotify: Sending id = SYSTEM_VIDEO0(1) (16777216)
Dec 13 16:20:53 (none) video: Wait for timeout, or incoming message
Dec 13 16:20:53 (none) video: registerAndWaitForNotify: Sync message received!
Dec 13 16:20:53 (none) video: fsm_procSetup: Signal tasks to run create.
Dec 13 16:20:53 (none) video: fsm_procSetup: wait for create(s) to finish
Dec 13 16:20:53 (none) video: fsm_procSetup: Signal tasks that operation can start.
Dec 13 16:20:53 (none) video: DDR2 Heap Memory: 12315/61056 Kbytes used
Dec 13 16:20:53 (none) audio: registerAndWaitForNotify: Sync message received!
Dec 13 16:20:53 (none) audio: fsm_procSetup: Signal tasks to run create.
Dec 13 16:20:53 (none) audio: fsm_procSetup: wait for create(s) to finish
Dec 13 16:20:53 (none) audio: fsm_procSetup: Signal tasks that operation can start.
Dec 13 16:20:53 (none) video: IRAM Heap Memory: 960/4096 bytes used
Dec 13 16:20:53 (none) video: Setup complete
Dec 13 16:20:53 (none) main: Thread Socket has TID 1776
Dec 13 16:20:54 (none) main: Thread CurlEngine has TID 1777
Dec 13 16:20:54 (none) main: 85.68 Phonebook I: LocalPhonebook::loadXMLFile '/config/pb.xml'
Dec 13 16:20:54 (none) main: ERROR: Hz detector is failing, assuming 50Hz lighting
Dec 13 16:20:54 (none) main: fsm_procSetup: Signal tasks that operation can start.
Dec 13 16:20:54 (none) main: 86.13 DATACTRL I: FECCCAPSREQ(): received global controller fecc capabilities
Dec 13 16:20:54 (none) main: 86.16 DnsLocator I: locatedAt() ipv4 unspec 192.168.185.195, port 536870911
Dec 13 16:20:54 (none) main: Thread KeyPad has TID 1778
Dec 13 16:20:54 (none) main: System ready
Dec 13 16:20:54 (none) main: System ready.
Dec 13 16:20:54 (none) main: Thread snmp has TID 1779
Dec 13 16:20:54 (none) main: Thread TshelldT has TID 1780
Dec 13 16:20:54 (none) main: tshelld: Listening to 127.0.0.1:4217
Dec 13 16:20:54 (none) main: Set Hz Detect to Auto
Dec 13 16:20:54 (none) main: 86.29 VIDEOLC-0 VLC_initAlloc_Req
Dec 13 16:20:54 (none) main: 86.29 VIDEOLC-0 VLC_initPendingInitCnf
Dec 13 16:20:54 (none) main: 86.30 Bluetooth I: BlueBerg::init() stack initialized
Dec 13 16:20:54 (none) main: 86.30 Bluetooth I: verbose() verbosity set to 0
Dec 13 16:20:54 (none) main: 86.30 Bluetooth I: secmode() security mode set to 1
Dec 13 16:20:54 (none) main: 86.30 Bluetooth I: toggleRadio() 0
Dec 13 16:20:54 (none) main: 86.30 Bluetooth I: listDevices()
Dec 13 16:20:54 (none) main: 86.31 CAMERA I: CamVisca::Init_doCAMInitReq
Dec 13 16:20:54 (none) main: 86.31 CAMERA I: CamVisca::sendCAMCameraListInd noOfCameras=1
Dec 13 16:20:54 (none) main: 86.31 CAMERA I: CamVisca::sendCAMPositionInd cameraId=1 pos=0/173/0/0
Dec 13 16:20:54 (none) main: 86.31 CAMERA I: doConfig
Dec 13 16:20:54 (none) main: 86.32 CAMERA I: CameraHandlerImpl::ConfigureCamera
Dec 13 16:20:55 (none) main: 86.36 VIDEOLC-0 VLC_commonSubscribeEvent_Req
Dec 13 16:20:55 (none) main: 86.50 MC I: Mcfsm::RegisterCnf()
Dec 13 16:20:55 (none) main: 86.51 SipStack I: SipEv: IDLE Subscribe to 'Manohar.E20@localhost' of type 'message-summary', unsolicited=1
Dec 13 16:20:55 (none) main: 86.52 MC W: Mcfsm::handleOtherMessages() unknown msg MS_RegisterKeepAlive_Cnf from MSCtrl
Dec 13 16:20:55 (none) main: 86.53 SipStack Stored config now has 1 profiles set
Dec 13 16:20:55 (none) main: 86.53 SipStack Incomplete config, staying idle
Dec 13 16:20:55 (none) main: 86.53 SipStack Stored config now has 2 profiles set
Dec 13 16:20:55 (none) main: 86.53 SipStack Stored config now has 3 profiles set
Dec 13 16:20:55 (none) audio: applstart: bye
Dec 13 16:20:55 (none) main: 86.83 Bluetooth I: deviceInfo() Voyager PRO UC v2 address: 48C1:AC:09B501 type: 2360324 status: bonded
Dec 13 16:20:55 (none) main: 86.83 Bluetooth I: statusMessage() status_lastDeviceInList (16) [48C1:AC:09B501]
Dec 13 16:20:55 (none) main: BluetoothSubscriber::updateStatus msg=Bluetooth_Status state=16
Dec 13 16:20:55 (none) main: 86.93 SipStack SipEvNotify- refreshing all active subscrriptions:
Dec 13 16:20:55 (none) main: 86.95 TMS I: provision(): http request url/http://192.168.150.69/tms/public/external/management/systemmanagementservice.asmx/789 bytes
Dec 13 16:20:55 (none) main: 86.95 VIDEOCTRL-0 I: (dsp,7) capacity 960
Dec 13 16:20:55 (none) main: 87.10 TMS I: provision(): tms query succeeded, length 1121
Dec 13 16:20:55 (none) main: 87.11 TMS I: executor(): Found heartbeat rate 0
Dec 13 16:20:55 (none) main: User (0) successfully executed command '/HttpFeedback/Register Expression[1]: /History/CallLogs/Call Expression[2]: /Status/Call[Status='Connected'] Expression[3]: /Status/H323/Gatekeeper Expression[4]: /Status/SIP/Registration Expression[5]: /Status/Network/Ethernet/Speed Expression[6]: /Event/CallSuccessful Expression[7]: /Event/Message/Prompt/Response FeedbackSlot: 3 ServerUrl: http://192.168.150.69/tms/public/feedback/code.aspx' from .
Dec 13 16:20:55 (none) main: 87.12 TMS I: executor(): cuil-processed buffer of 607 bytes
Dec 13 16:20:55 (none) main: 87.13 TMS I: provision(): ok ! heartbeat 0 ! upgrade no ! 0 files ! 0 docs
Dec 13 16:20:55 (none) main: 87.18 AUDIOCTRL-0 I: configure input connector intmic/spkr connector 1, subconnector 0
Dec 13 16:20:55 (none) main: 87.19 AUDIOCTRL-0 I: configure input connector headset connector 1, subconnector 0
Dec 13 16:20:55 (none) main: 87.19 AUDIOCTRL-0 I: configure input connector handset connector 1, subconnector 0
Dec 13 16:20:55 (none) main: 87.19 AUDIOCTRL-0 I: configure input connector bluetooth connector 1, subconnector 0
Dec 13 16:20:55 (none) main: 87.19 AUDIOCTRL-0 I: configure output connector intmic/spkr connector 1, subconnector 0
Dec 13 16:20:55 (none) main: 87.19 AUDIOCTRL-0 I: configure output connector headset connector 1, subconnector 0
Dec 13 16:20:55 (none) main: 87.19 AUDIOCTRL-0 I: configure output connector headset connector 2, subconnector 0
Dec 13 16:20:55 (none) main: 87.19 AUDIOCTRL-0 I: configure output connector handset connector 1, subconnector 0
Dec 13 16:20:55 (none) main: 87.20 AUDIOCTRL-0 I: configure output connector bluetooth connector 1, subconnector 0
Dec 13 16:20:55 (none) main: 87.24 APPL I: ApplFac:: -> DATACTRL:FECC_CAPS_REQ
Dec 13 16:20:55 (none) main: 87.24 APPL !ER RecordHandler->RecordHandler()
Dec 13 16:20:55 (none) main: 87.24 APPL I: ApplFac:: -> EVENT:StandbyReset
Dec 13 16:20:55 (none) main: 87.25 DATACTRL I: FECCCAPSREQ(): received global controller fecc capabilities
Dec 13 16:20:55 (none) main: 87.28 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:20:56 (none) main: Thread TshelldC has TID 1783
Dec 13 16:20:56 (none) osd: WARNING : Unexpected line received on tsh (expected line beginning with <XmlDoc> element) [ "Command not recognized." ]
Dec 13 16:20:56 (none) video: 0.00 LAYOUT-0 I: LAYOUT 0: Allocating 10240 bytes from VidMemMgr 1
Dec 13 16:20:56 (none) video: 0.00 LAYOUT-1 I: LAYOUT 1: Allocating 10240 bytes from VidMemMgr 1
Dec 13 16:20:56 (none) video: 0.00 DEC_FSM-0 I: configure width=1280,height=720,mbps=-1,memory=2830335
Dec 13 16:20:56 (none) video: 0.00 DEC_FSM-0 I: create png width=1280 height=720 mbps=-1 dec=ttvdec_png
Dec 13 16:20:56 (none) video: FrameStorageData_OpenNewFrame: Switching timing, max frame rate for 800x450 is 30
Dec 13 16:20:56 (none) video: 800x1152@30/1 co=922400 flags=0
Dec 13 16:20:56 (none) main: VPInput_Start: Videoport input started for frame storage 0
Dec 13 16:20:56 (none) main: Thread FS_VP_INPUT has TID 1784
Dec 13 16:20:56 (none) main: FrameStorageData_Init: Setting max size to 1280x720
Dec 13 16:20:56 (none) main: 87.80 MediaStreamController !ER SC::VIDEOREPORTIND unsupported gate type 3
Dec 13 16:20:56 (none) main: 87.92 MC I: Mc::CreateLocalParticipantResponse(p=1) ok
Dec 13 16:20:56 (none) main: 87.93 APPL I: ApplFac:: <- MC:CreateLocalParticipantResponse(p=1) reason=0/''
Dec 13 16:20:56 (none) main: 88.04 MediaStreamController !ER doVIDEOGATECONFIGURECNF() wrong type
Dec 13 16:20:56 (none) main: 88.16 MediaStreamController !ER doVIDEOGATECONFIGURECNF() wrong type
Dec 13 16:20:57 (none) main: VPOutput_Start: vpDispStart
Dec 13 16:20:57 (none) main: Thread FS_VP_OUTPUT has TID 1787
Dec 13 16:20:57 (none) main: FrameStorageData_Init: Setting max size to 1280x768
Dec 13 16:20:57 (none) video: 88.01 DEC_FSM-0 I: DEC_Decoding_doVIDDECStopReq
Dec 13 16:20:57 (none) video: 88.09 DEC_FSM-0 I: configure width=1280,height=720,mbps=-1,memory=2830335
Dec 13 16:20:57 (none) video: 88.21 DEC_FSM-0 I: create png width=1280 height=720 mbps=-1 dec=ttvdec_png
Dec 13 16:20:57 (none) main: 88.79 MediaStreamController !ER SC::VIDEOREPORTIND unsupported gate type 3
Dec 13 16:20:57 (none) main: 88.84 SipStack I: SipUa() SIPUA_Common_doSIPUASetGruu: 0 sip:Manohar.E20@gg.com;gr=urn:uuid:adc17cd6-1eb2-5e0b-bf0d-8acf2334c3bc
Dec 13 16:20:57 (none) main: 88.84 SipStack I: Setting 192.168.185.195 as new default outbound proxy.
Dec 13 16:20:57 (none) main: 88.94 VIDEOCTRL-0 I: VIDEOCTRL_doReadyGateConfigureReq: redundant signal for (inputimage,1) from (MSCtrl,0)
Dec 13 16:20:57 (none) main: 88.94 VIDEOCTRL-0 I: VIDEOCTRL_doReadyGateConfigureReq: redundant signal for (inputimage,3) from (MSCtrl,0)
Dec 13 16:20:57 (none) main: 88.94 VIDEOCTRL-0 I: VIDEOCTRL_doReadyMixerConfigureReq: redundant signal for mixer (rawvideo,1) from (MSCtrl,0)
Dec 13 16:20:57 (none) main: 88.94 MediaStreamController !ER doVIDEOGATECONFIGURECNF() wrong type
Dec 13 16:20:57 (none) main: 88.94 MC !ER TransactionActionStorage::cnfAction no match for Modify Mixer id(4)
Dec 13 16:20:59 (none) main: Thread TshelldC has TID 1789
Dec 13 16:21:00 (none) main: Thread TshelldC has TID 1791
Dec 13 16:21:00 (none) main: 91.72 MediaStreamController !ER SC::VIDEOREPORTIND unsupported gate type 3
Dec 13 16:21:00 (none) main: Thread TshelldC has TID 1793
Dec 13 16:21:01 (none) main: Thread TshelldC has TID 1796
Dec 13 16:21:01 (none) main: Thread TshelldC has TID 1798
Dec 13 16:21:02 (none) main: Thread TshelldC has TID 1800
Dec 13 16:21:02 (none) main: Thread TshelldC has TID 1802
Dec 13 16:21:03 (none) main: Thread TshelldC has TID 1804
Dec 13 16:21:04 (none) main: Thread TshelldC has TID 1806
Dec 13 16:21:04 (none) main: Thread TshelldC has TID 1808
Dec 13 16:21:05 (none) main: Thread TshelldC has TID 1810
Dec 13 16:21:05 (none) main: Thread TshelldC has TID 1812
Dec 13 16:21:05 (none) main: 97.26 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:05 (none) main: 97.28 SipStack I: SipUa() SIPUA_Common_doSIPUASetGruu: 0 sip:Manohar.E20@gg.com;gr=urn:uuid:adc17cd6-1eb2-5e0b-bf0d-8acf2334c3bc
Dec 13 16:21:06 (none) main: Thread TshelldC has TID 1816
Dec 13 16:21:06 (none) main: Thread TshelldC has TID 1817
Dec 13 16:21:06 (none) main: Thread TshelldC has TID 1819
Dec 13 16:21:07 (none) main: Thread TshelldC has TID 1821
Dec 13 16:21:07 (none) main: Thread TshelldC has TID 1823
Dec 13 16:21:07 (none) osd: Object::connect: No such signal TAbstractQueries::callForwardUpdated(int)
Dec 13 16:21:08 (none) osd: CRITICAL : Call history item 853 / QDateTime("Fri Dec 13 16:20:56 2013") Is not sorted by timestamp. Call logs may be distorted.
Dec 13 16:21:08 (none) main: Thread TshelldC has TID 1825
Dec 13 16:21:08 (none) main: Thread TshelldC has TID 1827
Dec 13 16:21:08 (none) osd: QFont::setPointSize: Point size <= 0 (-5), must be greater than 0
Dec 13 16:21:08 (none) osd: Object::connect: Parentheses expected, signal StatusCallList::updated
Dec 13 16:21:08 (none) osd: Object::connect: (sender name: 'Calllist')
Dec 13 16:21:09 (none) main: Thread TshelldC has TID 1829
Dec 13 16:21:09 (none) osd: QLayout: Attempting to add QLayout "" to TWaitingWidget "", which already has a layout
Dec 13 16:21:09 (none) main: Thread TshelldC has TID 1831
Dec 13 16:21:10 (none) osd: QLayout: Attempting to add QLayout "" to TWaitingWidget "", which already has a layout
Dec 13 16:21:10 (none) main: Thread TshelldC has TID 1834
Dec 13 16:21:10 (none) main: User (0) successfully changed configuration '/Conference[1]/DefaultCall[1]/Rate[1]' to '1152' from .
Dec 13 16:21:10 (none) main: User (0) successfully changed configuration '/Conference[1]/MaxUpstreamRate[1]' to '1152' from .
Dec 13 16:21:10 (none) main: User (0) successfully changed configuration '/Conference[1]/MaxDownstreamRate[1]' to '1152' from .
Dec 13 16:21:10 (none) main: User (0) successfully changed configuration '/Network[1]/DNS[1]/Server[1]/Address[1]' to '192.168.5.185' from .
Dec 13 16:21:10 (none) main: User (0) successfully changed configuration '/Network[1]/DNS[1]/Server[2]/Address[1]' to '10.242.29.18' from .
Dec 13 16:21:10 (none) main: User (0) successfully changed configuration '/Network[1]/DNS[1]/Domain[1]/Name[1]' to 'cts.com' from .
Dec 13 16:21:10 (none) main: User (0) successfully changed configuration '/NetworkServices[1]/NTP[1]/Mode[1]' to 'Manual' from .
Dec 13 16:21:10 (none) main: User (0) successfully changed configuration '/NetworkServices[1]/NTP[1]/Address[1]' to 'timesync.cts.com' from .
Dec 13 16:21:10 (none) main: User (0) successfully changed configuration '/Standby[1]/Control[1]' to 'On' from .
Dec 13 16:21:10 (none) main: User (0) successfully changed configuration '/Standby[1]/Delay[1]' to '1' from .
Dec 13 16:21:10 (none) main: Thread TshelldC has TID 1836
Dec 13 16:21:11 (none) main: Thread TshelldC has TID 1839
Dec 13 16:21:11 (none) osd: QLayout: Attempting to add QLayout "" to TWaitingWidget "", which already has a layout
Dec 13 16:21:12 (none) main: User (0) successfully executed command '/SystemUnit/AdminPassword/Set Password: Input Hidden' from .
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method TCallHistoryDirectory::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method NewMissedCallsHandler::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method XcomDirectory::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method TPictureFrameControllerOsd::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method Recording::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method BusyLampFieldPresenceProvider::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method Dialer::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method AdminSettingsMenu::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method Asteroids::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method CameraControl::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method BluetoothMenuFrame::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method IPSettings::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method ExposureSettings::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method InCall::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method BluetoothHandler::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method IPv6Settings::init()
Dec 13 16:21:12 (none) osd: QMetaObject::invokeMethod: No such method SystemInfo::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method TCallHistoryDirectory::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method TCameraControlWizardDialogFactory::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method TIncomingCallHandler::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method Web::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method ErrorManager::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method WhitebalanceSettings::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method Tetrix::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method TSystemModeFrame::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method WebWidgetsHandler::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method PresenceProvider::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method SoftwareUpgradeListener::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method SoftwareUpgradeMenu::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method MenuMagic::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method SetPasswordDialog::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method AdminSettings::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method TSimpleCallHistoryDirectory::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method TProvisioningWizardDialogFactory::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method ScreenSaverMenu::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method WebAppHandler::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method TURLFromConfigScreenSaver::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method LogoScreenSaver::init()
Dec 13 16:21:13 (none) osd: QMetaObject::invokeMethod: No such method IPChooser::init()
Dec 13 16:21:14 (none) osd: Object::connect: No such slot TApplication::stopHeldKeyTimer()
Dec 13 16:21:14 (none) osd: Object::connect: (receiver name: 'spider')
Dec 13 16:21:14 (none) osd: QLayout: Attempting to add QLayout "" to TWaitingWidget "", which already has a layout
Dec 13 16:21:14 (none) osd: Object::connect: No such signal TAbstractQueries::callForwardUpdated(int)
Dec 13 16:21:14 (none) osd: Object::connect: No such signal TAbstractQueries::lineCountChanged()
Dec 13 16:21:15 (none) osd: Object::connect: No such signal TAbstractQueries::callForwardUpdated(int)
Dec 13 16:21:15 (none) osd: Object::connect: No such signal TAbstractQueries::lineCountChanged()
Dec 13 16:21:15 (none) osd: INFO : GUI Initialized
Dec 13 16:21:15 (none) osd: PerformanceMilestones 106851725 : PHONEBOOK_PAINTED
Dec 13 16:21:16 (none) osd: PerformanceMilestones 107359526 : PHONEBOOK_PAINTED
Dec 13 16:21:20 (none) main: User (0) successfully executed command '/Phonebook/Search FolderId: Limit: 20 Offset: 0 SearchField: Name SearchString: ' from .
Dec 13 16:21:20 (none) main: User (0) successfully executed command '/Phonebook/Search FolderId: Limit: 20 Offset: 0 PhonebookId: SearchField: Name SearchString: ' from .
Dec 13 16:21:20 (none) osd: PerformanceMilestones 112082865 : PHONEBOOK_PAINTED
Dec 13 16:21:20 (none) osd: PerformanceMilestones 112116665 : PHONEBOOK_PAINTED
Dec 13 16:21:20 (none) osd: PerformanceMilestones 112157100 : PHONEBOOK_PAINTED
Dec 13 16:21:20 (none) osd: PerformanceMilestones 112209183 : PHONEBOOK_PAINTED
Dec 13 16:21:20 (none) osd: PerformanceMilestones 112259327 : PHONEBOOK_PAINTED
Dec 13 16:21:20 (none) osd: PerformanceMilestones 112310761 : PHONEBOOK_PAINTED
Dec 13 16:21:21 (none) osd: PerformanceMilestones 112360576 : PHONEBOOK_PAINTED
Dec 13 16:21:21 (none) osd: PerformanceMilestones 112411494 : PHONEBOOK_PAINTED
Dec 13 16:21:21 (none) osd: PerformanceMilestones 112462337 : PHONEBOOK_PAINTED
Dec 13 16:21:21 (none) osd: PerformanceMilestones 112512647 : PHONEBOOK_PAINTED
Dec 13 16:21:21 (none) osd: PerformanceMilestones 112562973 : PHONEBOOK_PAINTED
Dec 13 16:21:21 (none) osd: PerformanceMilestones 112683467 : PHONEBOOK_RESULT_RECEIVED
Dec 13 16:21:21 (none) osd: PerformanceMilestones 112686255 : PHONEBOOK_RESULT_RECEIVED
Dec 13 16:21:21 (none) osd: PerformanceMilestones 112815083 : PHONEBOOK_PAINTED
Dec 13 16:21:21 (none) osd: PerformanceMilestones 113257307 : PHONEBOOK_RESULT_RECEIVED
Dec 13 16:21:22 (none) osd: PerformanceMilestones 113454423 : PHONEBOOK_PAINTED
Dec 13 16:21:22 (none) main: 113.50 SipStack I: SipEv: Active Subscribe to 'sip:107980.jabber@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: 113.51 SipStack I: SipUa GRUU added OK
Dec 13 16:21:22 (none) main: 113.51 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 107980.jabber@gg.com' from .
Dec 13 16:21:22 (none) main: 113.57 SipStack I: SipEv: Active Subscribe to 'sip:8542764@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: 113.58 SipStack I: SipUa GRUU added OK
Dec 13 16:21:22 (none) main: 113.58 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8542764' from .
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: vishnukanth.tummala.e20@gg.com' from .
Dec 13 16:21:22 (none) main: 113.62 SipStack I: SipEv: Active Subscribe to 'sip:vishnukanth.tummala.e20@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: in.chn.collaboration@datacraft-asia.com' from .
Dec 13 16:21:22 (none) main: 113.66 SipStack I: SipEv: Active Subscribe to 'sip:in.chn.collaboration@datacraft-asia.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8535343' from .
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8512740' from .
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8535345' from .
Dec 13 16:21:22 (none) main: 113.70 SipStack I: SipUa GRUU added OK
Dec 13 16:21:22 (none) main: 113.71 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8512742' from .
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8565600' from .
Dec 13 16:21:22 (none) main: 113.77 SipStack I: SipEv: Active Subscribe to 'sip:8535343@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: mhari@gg.com' from .
Dec 13 16:21:22 (none) main: 113.79 SipStack I: SipEv: Active Subscribe to 'sip:8512740@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: 113.80 SipStack I: SipEv: Active Subscribe to 'sip:8535345@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: 113.80 SipStack I: SipEv: Active Subscribe to 'sip:8512742@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: mnl-mck.antila@gg.com' from .
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8522729' from .
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8565608' from .
Dec 13 16:21:22 (none) main: 113.89 SipStack I: SipEv: Active Subscribe to 'sip:8565600@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8575703' from .
Dec 13 16:21:22 (none) main: 113.94 SipStack I: SipUa GRUU added OK
Dec 13 16:21:22 (none) main: 113.94 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:22 (none) main: 113.95 SipStack I: SipEv: Active Subscribe to 'sip:mhari@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8515103' from .
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 609117103' from .
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: mnl-mck.caelum@gg.com' from .
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8525200' from .
Dec 13 16:21:22 (none) main: 114.08 SipStack I: SipEv: Active Subscribe to 'sip:mnl-mck.antila@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: 114.08 SipStack I: SipEv: Active Subscribe to 'sip:8522729@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: 114.09 SipStack I: SipEv: Active Subscribe to 'sip:8565608@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: joseph.korah@gg.com' from .
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8515109' from .
Dec 13 16:21:22 (none) main: 114.15 SipStack I: SipEv: Active Subscribe to 'sip:8575703@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8717102' from .
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8595900' from .
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8595903' from .
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: videohelpdesk.jabber@gg.com' from .
Dec 13 16:21:22 (none) main: 114.26 SipStack I: SipEv: Active Subscribe to 'sip:8515103@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: 114.26 SipStack I: SipEv: Active Subscribe to 'sip:609117103@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: 114.27 SipStack I: SipEv: Active Subscribe to 'sip:mnl-mck.caelum@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: 114.29 SipStack I: SipEv: Active Subscribe to 'sip:8525200@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:22 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: 8595904' from .
Dec 13 16:21:23 (none) main: 114.43 SipStack I: SipEv: Active Subscribe to 'sip:joseph.korah@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:23 (none) main: 114.46 SipStack I: SipEv: Active Subscribe to 'sip:8515109@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:23 (none) main: 114.55 SipStack I: SipEv: Active Subscribe to 'sip:8717102@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:23 (none) main: 114.58 SipStack I: SipEv: Active Subscribe to 'sip:8595900@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:23 (none) main: 114.59 SipStack I: SipEv: Active Subscribe to 'sip:8595903@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:23 (none) main: 114.62 SipStack I: SipEv: Active Subscribe to 'sip:videohelpdesk.jabber@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:23 (none) main: 114.87 SipStack I: SipEv: Active Subscribe to 'sip:8595904@gg.com' of type 'presence', unsolicited=0
Dec 13 16:21:23 (none) main: 115.20 SipStack I: SipUa GRUU added OK
Dec 13 16:21:23 (none) main: 115.21 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 115.36 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 115.38 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 115.43 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 115.44 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 115.48 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 115.49 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 115.55 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 115.56 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 115.65 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 115.66 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 115.70 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 115.71 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 115.81 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 115.82 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 115.90 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 115.90 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 115.95 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 115.95 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 116.01 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 116.02 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 116.08 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 116.09 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 116.17 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 116.17 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 116.26 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 116.27 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:24 (none) main: 116.33 SipStack I: SipUa GRUU added OK
Dec 13 16:21:24 (none) main: 116.35 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:25 (none) osd: PerformanceMilestones 116359632 : PHONEBOOK_PAINTED
Dec 13 16:21:25 (none) main: 116.45 SipStack I: SipUa GRUU added OK
Dec 13 16:21:25 (none) main: 116.46 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:25 (none) main: 116.53 SipStack I: SipUa GRUU added OK
Dec 13 16:21:25 (none) main: 116.53 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:25 (none) main: 116.59 SipStack I: SipUa GRUU added OK
Dec 13 16:21:25 (none) main: 116.60 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:25 (none) main: 116.66 SipStack I: SipUa GRUU added OK
Dec 13 16:21:25 (none) main: 116.67 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:25 (none) main: 116.72 SipStack I: SipUa GRUU added OK
Dec 13 16:21:25 (none) main: 116.73 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:25 (none) main: 116.80 SipStack I: SipUa GRUU added OK
Dec 13 16:21:25 (none) main: 116.81 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:21:25 (none) osd: PerformanceMilestones 117186315 : PHONEBOOK_PAINTED
Dec 13 16:21:25 (none) main: 117.24 APPL I: ApplFac:: -> EVENT:Standby secondsToStandby=30
Dec 13 16:21:27 (none) osd: PerformanceMilestones 118507975 : PHONEBOOK_PAINTED
Dec 13 16:21:27 (none) main: Thread TshelldC has TID 1880
Dec 13 16:21:27 (none) main: Thread TshelldC has TID 1882
Dec 13 16:21:28 (none) main: Thread TshelldC has TID 1884
Dec 13 16:21:28 (none) main: Thread TshelldC has TID 1886
Dec 13 16:21:28 (none) main: Thread TshelldC has TID 1888
Dec 13 16:21:29 (none) main: Thread TshelldC has TID 1890
Dec 13 16:21:29 (none) main: Thread TshelldC has TID 1892
Dec 13 16:21:29 (none) main: Thread TshelldC has TID 1894
Dec 13 16:21:55 (none) main: User (0) successfully executed command '/Key/Led Key: F1 State: Off' from .
Dec 13 16:21:55 (none) main: User (0) successfully executed command '/Key/Led Key: F2 State: Off' from .
Dec 13 16:21:55 (none) main: User (0) successfully executed command '/Key/Led Key: F3 State: Off' from .
Dec 13 16:21:56 (none) main: User (0) successfully executed command '/Key/Led Key: F4 State: Off' from .
Dec 13 16:21:56 (none) main: User (0) successfully executed command '/Key/Led Key: F5 State: Off' from .
Dec 13 16:22:42 (none) main: 193.37 SipStack W: SipEvNotify() Could not find user for Event: presence
Dec 13 16:22:43 (none) main: 195.26 SipStack W: SipEvNotify() Could not find user for Event: presence
Dec 13 16:22:52 (none) main: 203.37 SipStack W: SipEvNotify() Could not find user for Event: presence
Dec 13 16:22:53 (none) main: 205.23 SipStack W: SipEvNotify() Could not find user for Event: presence
Dec 13 16:22:55 (none) main: 207.09 SipStack W: SipEvNotify() Could not find user for Event: presence
Dec 13 16:22:57 (none) main: 208.98 SipStack W: SipEvNotify() Could not find user for Event: presence
Dec 13 16:24:02 (none) main: 273.54 SipStack W: SipEvNotify() Could not find user for Event: presence
Dec 13 16:24:04 (none) main: 275.45 SipStack W: SipEvNotify() Could not find user for Event: presence
Dec 13 16:24:22 (none) main: Thread TshelldC has TID 2163
Dec 13 16:24:22 (none) main: Thread TshelldC has TID 2165
Dec 13 16:24:42 (none) main: 313.50 SipStack W: SipEvNotify() Could not find user for Event: presence
Dec 13 16:24:44 (none) main: 315.42 SipStack W: SipEvNotify() Could not find user for Event: presence
Dec 13 16:24:55 (none) main: 326.96 SipStack I: SipUa GRUU added OK
Dec 13 16:24:55 (none) main: 326.96 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:24:56 (none) main: 327.52 SipStack rejected transmission:transid 5
Dec 13 16:24:56 (none) osd: PerformanceMilestones 328108058 : PHONEBOOK_PAINTED
Dec 13 16:25:12 (none) main: User (0) successfully executed command '/Presence/Subscribe/Start URI: in.chn.collaboration@datacraft-asia.com' from .
Dec 13 16:25:12 (none) main: 344.05 SipStack I: SipEv: Active Subscribe to 'sip:in.chn.collaboration@datacraft-asia.com' of type 'presence', unsolicited=0
Dec 13 16:25:12 (none) main: 344.05 SipStack I: SipUa GRUU added OK
Dec 13 16:25:12 (none) main: 344.05 SipStack SipTrnsp(tid=21) Altering parameters of Contact header
Dec 13 16:25:14 (none) osd: PerformanceMilestones 345481971 : PHONEBOOK_PAINTED
Dec 13 16:26:24 (none) main: 415.55 SipStack W: SipEvNotify() Could not find user for Event: presence
Dec 13 16:26:26 (none) main: 417.95 SipStack W: SipEvNotify() Could not find user for Event: presence
Dec 13 16:26:26 (none) main: 418.32 SipStack W: SipMsg_encode(): SIPMSG is not valid
Dec 13 16:26:26 (none) main: 418.33 SipStack W: SipEvNotify() Could not find user for Event: presence
Dec 13 16:26:26 (none) main: 418.33 SipStack !ER SIP_ASSERT, File: functional/protocols/sip/siptrlayfsm.c, Line 446
Dec 13 16:26:26 (none) main: Registers:
Dec 13 16:26:26 (none) main: R0: 00000002 R1: 00000000 R2: 00000002 R3: 99605603
Dec 13 16:26:26 (none) main: R4: 00e16160 R5: 00000002 R6: 017b2420 R7: 017a9410
Dec 13 16:26:26 (none) main: R8: 00e16160 R9: 001700a8 R10: 017acea8 FP: 4084caf4
Dec 13 16:26:26 (none) main: PC: 40769bf4 IP: 00dba540 SP: 4084cad0 LR: 008f99d8
Dec 13 16:26:26 (none) main: ERR: 00000017 CPSR: 20000010 FAULT: 00000000 TRAP: 0000000e
Dec 13 16:26:26 (none) main: OLDMSK: 00000000
Dec 13 16:26:29 (none) osd: WARNING : Unexpected line received on tsh (expected line beginning with <XmlDoc> element) [ "tshell: Remote closed connection" ]
Dec 13 16:26:30 (none) audio: uhpidsp: tx-buffer not free for 10 tries
Dec 13 16:26:30 (none) audio: uhpidsp: FATAL: communication with SYSTEM_MAIN is dead
Dec 13 16:26:30 (none) audio: uhpidsp: *** UHPI driver state ***
Dec 13 16:26:30 (none) audio: uhpidsp: Interface is alive
Dec 13 16:26:30 (none) audio: uhpidsp: Rx buffers pending: no
Dec 13 16:26:30 (none) audio: uhpidsp: Rx Counter: 395, Tx Counter: 33818
Dec 13 16:26:30 (none) audio: uhpidsp: Dsp to host buffer state:
Dec 13 16:26:30 (none) audio: uhpidsp: packet, status, length, dT (uS)
Dec 13 16:26:30 (none) audio: uhpidsp: [ 0] 33792, used, 36, 9999
Dec 13 16:26:30 (none) audio: uhpidsp: [ 1] 33793, used, 36, 10001
Dec 13 16:26:30 (none) audio: uhpidsp: [ 2] 33794, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [ 3] 33795, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [ 4] 33796, used, 36, 9999
Dec 13 16:26:30 (none) audio: uhpidsp: [ 5] 33797, used, 36, 10001
Dec 13 16:26:30 (none) audio: uhpidsp: [ 6] 33798, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [ 7] 33799, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [ 8] 33800, used, 36, 10004
Dec 13 16:26:30 (none) audio: uhpidsp: [ 9] 33801, used, 36, 9996
Dec 13 16:26:30 (none) audio: uhpidsp: [10] 33802, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [11] 33803, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [12] 33804, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [13] 33805, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [14] 33806, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [15] 33807, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [16] 33808, used, 36, 9999
Dec 13 16:26:30 (none) audio: uhpidsp: [17] 33809, used, 36, 10001
Dec 13 16:26:30 (none) audio: uhpidsp: [18] 33810, used, 36, 9999
Dec 13 16:26:30 (none) audio: uhpidsp: [19] 33811, used, 36, 10001
Dec 13 16:26:30 (none) audio: uhpidsp: [20] 33812, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [21] 33813, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [22] 33814, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [23] 33815, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [24] 33816, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [25] 33817, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [26] 33786, used, 36, 10000 <-
Dec 13 16:26:30 (none) audio: uhpidsp: [27] 33787, used, 36, 10000
Dec 13 16:26:30 (none) audio: uhpidsp: [28] 33788, used, 36, 10001
Dec 13 16:26:30 (none) audio: uhpidsp: [29] 33789, used, 36, 9999
Dec 13 16:26:30 (none) audio: uhpidsp: [30] 33790, used, 36, 9998
Dec 13 16:26:30 (none) audio: uhpidsp: [31] 33791, used, 36, 10002
Dec 13 16:26:30 (none) audio: uhpidsp: Host to dsp buffer state:
Dec 13 16:26:30 (none) audio: uhpidsp: [ 0] 384, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [ 1] 385, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [ 2] 386, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [ 3] 387, free, 64, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [ 4] 388, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [ 5] 389, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [ 6] 390, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [ 7] 391, free, 64, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [ 8] 392, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [ 9] 393, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [10] 394, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [11] 363, free, 72, 0 <-
Dec 13 16:26:30 (none) audio: uhpidsp: [12] 364, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [13] 365, free, 64, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [14] 366, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [15] 367, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [16] 368, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [17] 369, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [18] 370, free, 64, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [19] 371, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [20] 372, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [21] 373, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [22] 374, free, 64, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [23] 375, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [24] 376, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [25] 377, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [26] 378, free, 64, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [27] 379, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [28] 380, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [29] 381, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [30] 382, free, 72, 0
Dec 13 16:26:30 (none) audio: uhpidsp: [31] 383, free, 64, 0
Dec 13 16:26:30 (none) audio: Audiomcaspraw: 334668 ms since started
Dec 13 16:26:30 (none) audio: SW invoked abort()/exit()
Dec 13 16:26:30 (none) audio: called from:
Dec 13 16:26:30 (none) audio: Task: FsmAud
Dec 13 16:26:30 (none) audio: DSP/BIOS version:5200
Dec 13 16:26:30 (none) audio: Task State Pri Scheduled StackBase StackSize MinUnused
Dec 13 16:26:30 (none) audio: -----------------------------------------------------------------
Dec 13 16:26:30 (none) audio: flashLed BLOCKED 4 332 0x80e74358 1024 881
Dec 13 16:26:30 (none) audio: dumprmsl BLOCKED 4 1 0x80e747f8 3072 1865
Dec 13 16:26:30 (none) audio: mcaspaud BLOCKED 12 33468 0x10017f38 2048 1489
Dec 13 16:26:30 (none) audio: TimerThr BLOCKED
Dec 13 16:26:30 (none) audio: WatchDog BLOCKED 1 336 0x80e89a68 4096 3617
Dec 13 16:26:30 (none) audio: FsmAudTe BLOCKED 10 4 0x80ef5d08 102400 102089
Dec 13 16:26:30 (none) audio: FsmAudHi BLOCKED 12 602 0x80f0ee20 8192 7229
Dec 13 16:26:30 (none) audio: FsmAud RUNNING 12 33549 0x1001da98 13312 8233
Dec 13 16:26:30 (none) audio: ComRoute BLOCKED 4 3 0x80f11308 8192 7881
Dec 13 16:26:30 (none) audio: timestam BLOCKED 1 1 0x80fd5138 16384 16217
Dec 13 16:26:30 (none) audio: dMaxWait BLOCKED 1 1 0x80fd91f8 16384 16153
Dec 13 16:26:30 (none) audio: UhpiRxDs BLOCKED 13 385 0x80fe0b98 2560 2193
Dec 13 16:26:30 (none) audio: ApplStrt TERMINATED 12 157 0x81003a68 6144 4337
Dec 13 16:26:30 (none) audio: TSK_idle READY 0 67297 0x1003d8a0 1024 637
Dec 13 16:26:30 (none) audio: Semaphore Count Pending First
Dec 13 16:26:30 (none) audio: dbgrmsle 0 1 dumprmsl
Dec 13 16:26:30 (none) audio: mcaspraw 0 1 mcaspaud
Dec 13 16:26:30 (none) audio: mcaspbt_ 1 0
Dec 13 16:26:30 (none) audio: mcaspfpg 1 0
Dec 13 16:26:30 (none) audio: Clm 1 0
Dec 13 16:26:30 (none) audio: timestam 0 1 timestam
Dec 13 16:26:30 (none) audio: waitlog 0 1 dMaxWait
Dec 13 16:26:30 (none) audio: printBuf 1 0
Dec 13 16:26:30 (none) audio: uhpiNewB 0 1 UhpiRxDs
Dec 13 16:26:30 (none) audio: Mutex Type Count Owner Pending First
Dec 13 16:26:30 (none) audio: mcaspraw INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: mcaspbt_ INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: mcaspfpg INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: comroute INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: OutRecvL INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: pool_7 INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: pool_6 INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: pool_5 INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: pool_4 INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: pool_3 INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: pool_2 INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: pool_1 INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: pool_0 INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: FsmTimer INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: dmaxMute INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: GlobalLo INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: COM mute INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: uhpiWP INHERIT 1 FsmAud 1 FsmAudHi
Dec 13 16:26:30 (none) audio: TTOSmute INHERIT 0 - 0 -
Dec 13 16:26:30 (none) audio: Heap HeapStart TotalSize Unused MaxFree
Dec 13 16:26:30 (none) audio: SDRAM 0x800062f0 16777216 14799528 14796160
Dec 13 16:26:30 (none) audio: IRAM 0x100017bc 210000 2464 1712
Dec 13 16:26:30 (none) audio: Queue Size Unused MsgSize Msgs Pending First
Dec 13 16:26:30 (none) audio: Qfsmaudt 20 20 4 0 1 FsmAudTe
Dec 13 16:26:30 (none) audio: Qfsmaudh 5 5 4 0 0
Dec 13 16:26:30 (none) audio: Qfsmaud 250 215 4 35 0
Dec 13 16:26:30 (none) audio: ComRoute 50 50 4 0 1 ComRoute
Dec 13 16:26:30 (none) audio: *** platform/signal_handler/dspbios/exit_handler.c(38): Dumping pools start
Dec 13 16:26:30 (none) audio: Pool stats 0:
Dec 13 16:26:30 (none) audio: UHPI_DSP- 0 -> AUD10MS- 0 AUD10MS_timerEvent: count: 18
Dec 13 16:26:30 (none) audio: CLKSYNC- 1 -> CLKSYNC- 0 CLKSYNC_Get_Clk_Req: count: 1
Dec 13 16:26:30 (none) audio: ***- -1 -> ***- -1 POOL_msg: count: 1
Dec 13 16:26:30 (none) audio: Pool stats 320:
Dec 13 16:26:30 (none) audio: MCASPRAW- 0 -> AUDLOCALOUT- 0 AUDLOCALOUT_TICK: count: 18
Dec 13 16:26:30 (none) audio: FSM_TIMER- 0 -> CLKSYNC- 1 CLKSYNC_Sync_Iter: count: 1
Dec 13 16:26:30 (none) audio: AUD10MS- 0 -> RtpStack- 0 AUD10MS_event: count: 1
Dec 13 16:26:30 (none) audio: Pool stats 384:
Dec 13 16:26:30 (none) audio: ***- -1 -> ***- -1 POOL_msg: count: 200
Dec 13 16:26:30 (none) audio: Pool stats 960:
Dec 13 16:26:30 (none) audio: AUDIOCTRL- 0 -> ***- -1 POOL_msg: count: 2
Dec 13 16:26:30 (none) audio: ***- -1 -> ***- -1 POOL_msg: count: 10
Dec 13 16:26:30 (none) audio: Pool stats 1024:
Dec 13 16:26:30 (none) audio: Pool stats 2112:
Dec 13 16:26:30 (none) audio: ***- -1 -> ***- -1 POOL_msg: count: 12
Dec 13 16:26:30 (none) audio: Pool stats 2176:
Dec 13 16:26:30 (none) audio: ***- -1 -> ***- -1 POOL_msg: count: 100
Dec 13 16:26:30 (none) audio: Pool stats 5056:
Dec 13 16:26:30 (none) audio: ***- -1 -> ***- -1 POOL_msg: count: 40
Dec 13 16:26:30 (none) audio: *** Dumping pools end
Dec 13 16:26:30 (none) audio: *** Dumping proc start
Dec 13 16:26:30 (none) audio: Module numbe
Dec 13 16:26:30 (none) audio: 0x10021fdc: ***-1 message ********** from ***--1
Dec 13 16:26:30 (none) audio: 0x10020ea4: AUD10MS-0 message AUD10MS_timerEvent from UHPI_DSP-0
Dec 13 16:26:30 (none) audio: 0x1001d8bc: CLKSYNC-1 message CLKSYNC_Sync_Iter from FSM_TIMER-0
Dec 13 16:26:30 (none) audio: Module number too high, something is amiss.
Dec 13 16:26:30 (none) audio: 0x1001d5e4: ***-1 message ********** from ***--1
Dec 13 16:26:30 (none) audio: *** Dumping proc end
12-13-2013 04:51 AM
Does it reboot as well when its not connected to the network?
Looks like it could be some error with presence.
Is sip:in.chn.collaboration@datacraft-asia.com
on your contact list, does it change the behavior if you remove that one?
There is some newer software version 4.1.3 out, you could check that as well.
Please remember to rate helpful responses and identify helpful or correct answers.
12-13-2013 04:56 AM
Hi Martin,
I am aware of the bug CSCue59199 that affects Presence and crash the endpoint.
But we have the fix for that here in place already.
Should this be a Hardware issue.
12-13-2013 05:30 AM
Did you disconnect the network just to see if it still reboots?
Did you check if the problem still exists after removing all contacts?
Did you check if it reboots after you did a factory default reset?
Did you check if it reboots after you did the upgrade to 4.1.3?
Before saying its a hardware thing there is at least multiple things to check on.
At least the last thing before things look not ok was a presence message, not sure if
its that bug or something in addition, but at least worth checking.
Is there a special reason that you think its a hardware fault? If you have a service contract
consider escalating this case to Cisco TAC.
12-15-2013 10:41 PM
It is purely something to do with SIP.
Since, reboot stops after disabling SIP.
12-16-2013 03:01 AM
Presence is only done via sip.
Upgrade to the latest and if you need sip / presence and you have a service contract escalate this
thread to Cisco TAC
Rameez: Please remember to rate helpful responses and identify helpful or correct answers.
10-30-2014 05:11 AM
Am facing the same issue . Do we have a fix for this issue .
91234.00 SipStack W: SipEvNotify() Could not find user for Event: presence
91234.79 SipStack W: SipMsg_encode(): SIPMSG is not valid
91234.80 SipStack W: SipEvNotify() Could not find user for Event: presence
91234.81 SipStack !ER SIP_ASSERT, File: functional/protocols/sip/siptrlayfsm.c, Line 446
