EDID profiles
Bob Fitzgerald
Level 4
Level 4
Hello!
Are there any EDID "profiles" available for the C-series codecs?  A customer is asking if any exist because of an issue he is having with a HDMI router.  He would like to pass them on to the router manufacturer's support people for interop testing.
Thanks!
Dharmesh Nandoria
Hi Bob ,
C60 use diffrent commnad .
log in to codec using admin ( root login should be enabled )
  $$$$$$$ For HDMI 1 $$$$$$$$$$
sys-con vpe0   ***** Commnad
****** Welcome to SYSTEM_VPE0 ******
Use 'quit' to end connection
OK
Connected
print edid     ****** Commnad
Main EDID:
Manufacturer: SAM(19501)
ProductCode: 2203
SerialNumber: 1515603284
WeekOfManufacture: 12
YearOfManufacture: 2012
EDIDVersionNumber: 1
EDIDRevisionNumber: 3
SignalLevel: Digital
SignalLevelStandard:
Setup:
SupportsSeparateSyncs:
SupportsCompositeSync:
SupportsSyncOnGreen:
SerrationRequired:
DFPSupported: No
DisplaySizeKnown: No
Max Horizontal Image Size = 51 cm
Max Vertical Image Size = 29 cm
Nearest Known Aspect Ratio = 16:9
DisplayTransferCharacteristic: (120 + 100.0)/100.0
SupportsDPMSStandby: No
SupportsDPMSSuspend: No
SupportsDPMSActiveOff: Yes
SupportsDefaultColorSpace_sRGB: No
SupportsPreferredTimingMode: Yes
SupportsDefaultGTF: No
ColorCharacreristics: R (633,340), G (320,622), B (155,042), W (313,329)
Established Timings:
    800x600@60Hz
    800x600@56Hz
    640x480@75Hz
    640x480@72Hz
    640x480@67Hz
    640x480@60Hz
    720x400@70Hz
    1280x1024@75Hz
    1024x768@75Hz
    1024x768@70Hz
    1024x768@60Hz
    832x624@75Hz
    800x600@75Hz
    800x600@72Hz
Standard Timing Identification:
    Refresh rate: 75Hz
    Horizontal active pixels: 1152
    Image aspect ratio: 4:3
    Refresh rate: 60Hz
    Horizontal active pixels: 1280
    Image aspect ratio: 16:9
    Refresh rate: 60Hz
    Image aspect ratio: 16:10
    Refresh rate: 60Hz
    Image aspect ratio: 5:4
    Refresh rate: 60Hz
    Horizontal active pixels: 1440
    Refresh rate: 60Hz
    Horizontal active pixels: 1600
    Refresh rate: 60Hz
    Horizontal active pixels: 1680
Monitor Descriptor Data (Type = Monitor Range Limits):
    Min vertical rate: 50 Hz
    Max vertical rate: 75 Hz
    Min horizontal rate: 30 kHz
    Max horizontal rate: 81 kHz
    Max pix clk: 170 MHz
    No secondary timing formula supported
Monitor Descriptor Data (Type = Monitor Name):
    S23B370
Detailed Timing Description:
    PixelClockDiv10000 : 14850
    Horizontal Active : 1920
    Horizontal Blanking : 280
    Vertical Active : 1080
    Vertical Blanking : 45
    Horizontal Sync Offset : 88
    Horizontal SyncPulse Width : 44
    Vertical Sync Offset : 4
    Vertical SyncPulse Width : 5
    Horizontal Image Size : 510 mm
    Vertical Image Size : 287 mm
    Horizontal Border : 0
    Vertical Border : 0
    Flags : 0x0000001e
    - Non-Interlaced
    - Normal display, no stereo
    PixelClockDiv10000 : 7425
    Horizontal Active : 1280
    Horizontal Blanking : 370
    Vertical Active : 720
    Vertical Blanking : 30
    Horizontal Sync Offset : 110
    Horizontal SyncPulse Width : 40
    Vertical Sync Offset : 5
    Vertical Border : 0
    Flags : 0x0000001e
    - Non-Interlaced
Extension flag (#extension-blocks) : 1
CEA-861-D EDID:
Revision Number : 3
Number of native DTDs: 1
Underscan IT by default: Yes
Basic audio support: No
YCbCr 4:4:4 support: Yes
YCbCr 4:2:2 support: Yes
Video block
    1920x1080@60p 16:9 Native
    1280x720@60p 16:9
    1920x1080@50p 16:9
    1280x720@50p 16:9
    720x576@50p 16:9
    720x480@60p 16:9
HDMI Vendor
    IEEE Reg Id: 0x000c03
    Source Physical Address (A.B.C.D) = (1.0.0.0)
    Supports AI: No
    Supports 30 bits/pixel (10 bits/color): No
    Supports 36 bits/pixel (12 bits/color): No
    Supports 48 bits/pixel (16 bits/color): No
    Supports YCbCr 4:4:4 in Deep Color modes: No
    Supports DVI dual-link operation: No
    Horizontal Blanking : 700
    Horizontal Sync Offset : 440
    Vertical Sync Offset : 21
    Vertical Border : 0
    Flags : 0x0000001e
    - Non-Interlaced
    PixelClockDiv10000 : 2700
    Horizontal Active : 720
    Horizontal Blanking : 144
    Vertical Active : 576
    Vertical Blanking : 49
    Horizontal Sync Offset : 12
    Horizontal SyncPulse Width : 64
    Vertical Border : 0
    Flags : 0x00000018
    - Non-Interlaced
    Horizontal Blanking : 138
    Vertical Active : 480
    Horizontal Sync Offset : 16
    Horizontal SyncPulse Width : 62
    Vertical Sync Offset : 9
    Vertical SyncPulse Width : 6
    Vertical Border : 0
    Flags : 0x00000018
    - Non-Interlaced
OK
quit
Connection ended
For HDMI 2 & DVI 2
sys-con vpe1
****** Welcome to SYSTEM_VPE1 ******
OK
Connected
print edid
Main EDID:
ProductCode: 2203
Setup:
SerrationRequired:
DFPSupported: No
    800x600@60Hz
    800x600@56Hz
    640x480@75Hz
    640x480@72Hz
    640x480@67Hz
    640x480@60Hz
    720x400@70Hz
    1280x1024@75Hz
    1024x768@75Hz
    1024x768@70Hz
    1024x768@60Hz
    832x624@75Hz
    800x600@75Hz
    800x600@72Hz
    Refresh rate: 75Hz
    Refresh rate: 60Hz
    Refresh rate: 60Hz
    Refresh rate: 60Hz
    Refresh rate: 60Hz
    Refresh rate: 60Hz
    Refresh rate: 60Hz
    S23B370
    Vertical Border : 0
    Flags : 0x0000001e
    - Non-Interlaced
    Vertical Border : 0
    Flags : 0x0000001e
    - Non-Interlaced
CEA-861-D EDID:
Revision Number : 3
Video block
    1280x720@60p 16:9
    1920x1080@50p 16:9
    1280x720@50p 16:9
    720x576@50p 16:9
    720x480@60p 16:9
HDMI Vendor
    Supports AI: No
    Vertical Border : 0
    Flags : 0x0000001e
    - Non-Interlaced
    Vertical Border : 0
    Flags : 0x00000018
    - Non-Interlaced
    Vertical Border : 0
    Flags : 0x00000018
    - Non-Interlaced
OK
quit
Connection ended
for DVI 3
sys-con vpe2
****** Welcome to SYSTEM_VPE2 ******
OK
Connected
print edid
ad9389b: no edid read
hth
Kind regards,
Dharmmesh
