EX90 Touchscreen settings password
rpadfield
Does anyone know how to set a password onto a touch screen / pad to stop users accessing the network settings?
Many thanks,
Rob
John Regan
You can login to the codec using SSH and login as admin and enter the following command, changing the "123" for the password you want.
xcom SystemUnit menupassword set Password: "123"
This from TC4.1 release notes
•    Support for password protection of the touch panel advanced settings. This is set using the ‘xCommand SystemUnit MenuPassword Set’ command from the API.
John Regan
