12-27-2017 03:52 AM - edited 03-18-2019 01:43 PM
EX90 message ... Lost connection with control device. I did factory reset.
It took ip from DHCP. and again... Lost connection with control device.
and i can not web access to.
please direct .
12-27-2017 04:22 PM
First thing to check would be that the Touch8 panel is correctly connected to the back of the EX90. Try unplugging it and re-plugging it a couple of times in case the connectors have oxidised. Does the Touch8 power up, and if so, what shows on it?
12-29-2017 09:36 AM
It shows Cisco logo in booting up but after that is black .(do not shows anything).
01-03-2018 09:53 PM
Does your EX90 power up properly if you disconnect the Touch8? If so, the Touch8 may be faulty and could need to be RMA'd.
01-05-2018 09:47 PM
No, if touch8 connected or disconnected ---> " Lost connection with control device"
and no access with browser (IP Access).
01-07-2018 06:58 PM - edited 01-07-2018 07:02 PM
If it's still not booting properly, you could connect via the serial port and see if you can see what is happening. Note: a standard serial cable will not work, you will need one with an RS232 to TTL/CMOS converter in it - there's a guide to making one, or using a Nokia CA-42 USB data cable.
Otherwise, your best bet would be to log a call with the Cisco TAC as the unit and/or Touch8 may be faulty and need an RMA.
