Does anyone have an example of the format of the CSV file for migrating op prem endpoints to control hub using the device connector tool?
I did this per the instructions:
"To create the file from TMS, export a System Overview report and only select the Network Settings > Hostname system parameter. Manually add columns for Username and Password.
For the CSV file, you need to create columns for Address, Username, and Password."
When I try to upload the CSV file, I am getting an invalid format error.
Unfortunately, Cisco did not put an example in their instructions...
