Exp Unsupported URI Scheme
ezlan
Hi;
I have a new deployment Exp C and E also trunk with CUCM for B2B calls but i've got failure like unsupported uri scheme.
My exp's software vers. 8.8.3 and my zone's are active between exp c and e also with cucm is looks active and ok.
I've edited my search rules on the exp c but when i receive calls from outside it's giving "uri unsupported scheme". I've added the snaps. What can i do to solve this?
With Regards,
Have you looked on your Expressway-E to see what it is seeing and doing with the call once you have sent it there from the Expressway-C?
It seems that your Expressway-E may not be handling the call correctly and passing it back to the Expressway-C and (as in image 4) causing a loop.
Had the DNS been set up correctly on the Expressway-E - can it resolve bkm.com.tr?
Has the DNS Zone been correctly configured?
What happens when you do a test search for the 1050@bkm.com.tr on the Expressway-E ?
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
