12-04-2018 09:02 AM - edited 03-18-2019 02:29 PM
We are installing an Expressway-E with the capacity of B2B calls, but when it calls from internet to expressway public IP the call shows "unreacheable". the log, only shows:
I don't know what it means.
It does not matter if I change the search rules, the behavior is the same, then there is something additional to validate the fail. Please help me with the issue.
12-22-2018 10:53 PM
Are you just dialling the IP of Expressway?
If yes, then it will be like that because you need to dial some end number.
I just tested it in my lab and get the same result.
Search (4)
State: Completed
Found: False
Reason: Address Incomplete
Type: H323 (Setup)
CallSerial Number: d5362edc-91cc-4410-ab85-71733dcfd31c
Tag: d6a0b5ac-d3d1-4097-aa2d-a0e4a3baec63
Source (1)
Authenticated: False
Aliases (1)
Alias (1)
Type: H323Id
Origin: Unknown
Value: h323:10.104.xx.xx
Zone (1)
Type: Default
Destination (1)
Alias (1)
Type: IPAddress
Origin: Unknown
Value: 10.106.xx.xxx
StartTime: 2018-12-23 12:19:39
Duration: 0.01
So you need to dial number@IP and this pattern should be routable via search rules to some destination.
Thanks.
Please rate if it is helpful....
11-24-2020 11:47 PM
page 212
Configure Fallback alias. It's the default URI where route such calls. For example I wrote here CMS's IVR URI
