expressway E public CA with godaddy
hi guys,
I just signed expressway E cert with godaddy. during the download of the cert from godaddy it asks for server type.  the types are IIS, exchange, tomcat, other and few more (see attached).  I am not sure which one I should download. any one has any thoughts?
thanks
vijay
Elias Sevilla Duarte
IIS is normally used for web servers, in the other hand Tomcat is used for added encryption security using TLS, so I recommend using Tomcat.
7 Replies 7
Alok Jaiswal
Level 4
Level 4
You can use tomcat, because expressway use tomcat. Though i guess if you download as IIS you would still be able to apply that on the expressway.
Alok
I have used IIS before and it works fine.
Raaj
i could not upload the downloaded iis CAs to E
how did you do yours?
thank you guys. I will try the tomcat and let you know if anything.
vijay
Hi Elias,
Why do you think tomcat is for TLS and not SSL ?
CUCM, Expressway all uses apache tomcat as web server.
Alok
I downloaded using tomcat.I uploaded the root and server CAs to E
I uploaded only root to C
Tls negotiation failure
can you help?
