05-14-2022 05:53 AM - edited 05-15-2022 05:01 AM
On ExpresswayE GUI for calls we can see that MRA calls uses CollaborationEdgeZone but this zone does not show up on Expressway links or on XConfiguration commands. Also CCO does not document this zone anywhere.
How this zone can be verified?
Where this zone configuration get saved?
How this zone configuration gets updated?
Also, there are no search rules on ExpresswayE (on GUI) when using MRA. How calls get routed?
05-15-2022 11:03 PM
I think, this zone is an "internal" zone in EXP-E. So, not visible for the admin.
My guess is, that as soon as you set the EXP-E to serve MRA, this zone gets configured automatically and is "active" all the time. So, you don't need to or can't configure it manually (also since there are not changes to do from the admin's point of view).
About the search rules:
You don't need to manually configure search rules on EXP-C and E, for MRA to work.
05-16-2022 06:50 PM
No document on CCO about it...
