11-21-2013 03:30 AM - last edited on 03-25-2019 09:10 PM by ciscomoderator
I just freshly installed a TS320 and tried an upgrade to the latest version, from 3.1(80) to 3.1(95). After the upgrade the TS fails to boot.
I can see that log messages at the console:
121648.380 MEDIA : Info : -------------------------------------------------------------
121648.380 MEDIA : Info : | Blade | Type | Audio | Video | Mixed | Media Tokens |
121648.380 MEDIA : Info : | * 1 | 320 | 0 (0) | 0 (3) | 0 (1) | 0/25680 |
121648.380 MEDIA : Info : allow 0% overload of DSPs in dsp_placement
121648.380 MEDIA : Info : adjust limit on mixed DSP video to 76% (0 DSPs)
121648.380 MEDIA : Info : refresh_dsp_placement_costs av_penalty=500, max_Ad=0, max_Ae=0/0, max_Vd=32, max_Ve=32
121648.380 DSP_PLACEMENT : Info : Changed DSP hard overload limit (percent) for limit 0: 50 --> 0
121657.439 NETCONF : Info : media connect on vfx0 (3)
Nov 21 12:17:07 tlr_boot[740]: tlr 2: status code timeout 00000000
Nov 21 12:17:07 tlr_boot[740]: tlr 3: status code timeout 00000000
Nov 21 11:17:07 tlrmond[715]: new local connection on
Nov 21 12:17:09 tlr_upload[751]: tlr 0: probe okay
Nov 21 12:17:09 tlr_upload[751]: tlr 1: probe okay
Nov 21 12:17:09 tlr_upload[751]: tlr 2: probe okay
Nov 21 12:17:09 tlr_upload[751]: tlr 3: probe okay
Nov 21 12:17:09 tlr_upload[751]: hpi_read_u32: hpi controller timeout 01
Nov 21 12:17:09 tlr_upload[751]: hpi_write_multi: hpi controller timeout 01
121717.451 SYSLOG : Info : sending IPv4 from default port
121717.451 SYSLOG : Info : sending IPv6 from default port
*** DSP 0 asystolic ***
*** DSP 0 failure detected: partner will master reboot ***
*** DSP 1 asystolic ***
*** DSP 1 failure detected: partner already dead ***
121727.501 MEDIA : Info : DSP 1: restart not supported
DSP 1 recovery is not supported. Reboot.
121732.259 SYSTEM : Info : shutdown monitor - shutdown initiated
121732.260 C_LINK : Info : shutdown started
121732.260 MEDIA : Info : shutdown initiated
121732.426 MEDIA : Info : shutdown now complete
121732.760 SYSTEM : Info : shutdown process - all priority 100 handlers complete
121732.760 SYSTEM : Info : shutdown process - shutdown complete
It seems like there is an issue with the DSPs.
Is it possible to restore another image via USB or so?
Paul
11-21-2013 03:35 AM
Additional Info:
The system constantly reboots and is not reachable over LAN. So I cannot downgrade via HTTP.
Paul
