Firewall Port Utility?
Patrick Cooke
Hello All,
I've seen a similar post from years ago but I am looking for an updated solution. In the past, we've used the Tandberg "IPT.exe" firewall tester but we are looking to see if anyone has created a tester which reflect the new port requirements of cisco endpoints traveling through a firewall to a VCS expressway or CUMC?
Patrick Sparkman
I remember such posts from long ago, but haven't seen anything in so long regarding such a tool.
It might not be the same, but you could possibly use the VCS service checker tool that is avaliable online at Cisco.com.  It will check common VCS and CUCM records, as well as try to make TCP connections using said records.
