Forwarding Call To Another Phone After X Rings
agruszcynski
I have a 7940 phone where the end user wants the phone calls to that phone to be forwarded to another phone after 3 rings on the first phone. Is this possible, and if it is how do you go about configuring this situation in Call Manager. I have Call Manager 6.1 running.
Marwan ALshawi
go to the directory number setting
in the call forwarding section
In the No Answer Ring Duration field, enter the number of seconds that the line will ring before forwarding to the Forward No Answer destination. If this field is left blank, the value configured in CallManager service parameter is used.
if helpful Rate
Marwan ALshawi
if helpful Rate
hai marw,
one of my end user requirment is like this,
if somebody calling to pilot number and that extension is 500.500 picks the call, and he wants talk to 501 .
but the 501 guy not in seat...my question is
if the 500 extension can able to transfer the
the call to 501's moblie number by pressing transfer button...if it is possible give me the solution
NOTE:call forward is not enable in 501's ip phone.
thanks
